Question about Mitsubishi VS-60603 60" Rear Projection Television
No picture mitsu 60603
Can you describe where on the green board, the 1" chip is that usually gets fluid leak on it?
Mitsubishi 60603
  • Mitsubishi Master
  • 8,617 Answers
Its about 3/4 of the way up that board on the left hand side its the vertical output ic mounted to a aluminum heat sink
Posted on May 28, 2008
Mitsu vs60603 menu ?
actualy the only wat to reset is to unplug the power cord for 1 minute the plug it back in.
Aug 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Tip
VZ5 Chassis mitsubishi VS-60603 With excessive brightness
If experiencing excessive brightness in the VZ5 chassis mitsubishi's it usually can be traced back to a leaky transistor on one of the CRT PC boards. Check Q6R1 on Red PCB, Q6B1on the Blue PCB and Q6G1 on the Green PCB one of these transistors will most likely be leaky
on Feb 23, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi vs-60603 lamp replacement
the VS 60603 has picture tubes three of them called CRTs you can get replacements at the following link.
http://servicemanuals.vstore.ca/
Aug 17, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Big screen won't work
also a color wheel that has gone out ..replace it.
May 20, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsu Problem Resolved??
After about a week I got it to turn on but still no picture just a white beam about 2/4 down on the screen and still has sound
Apr 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Sound but no picture
It may be fluid from the picture tubes. They have a silicon based fluid inside the lens housing that helps keep them cool, unfortunantly the fluid in this model leaks. The fluid is corrosive but not conductive, meaning that it can sit on the board long enough to eat through the board but not short it out. There is a 1" square ic on the main board (large green board on the left) usually if there is fluid damage it will be there and you will know it by:
1. green residue all over or around chip
2. clear fluid on the board.
This is a very common problem and is almost always catistropic. Meaning that the tv is not repairable. I hope you don't have this problem but chances are that you do or will in the near future with this model. This is just a guide as to where the fluid may be on the board, but it may be anywhere. Hope this helps.
Apr 02, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
