Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
When i put the power in port number 7 is always on, why?
    Scholar:
  • 55 Answers
If the port light is always on even if you dont have any thing connected on it then it seems to be a hardware issue.
Please connect a computer on that port and see if its getting the connectivity.
Regards,
Rashish
Posted on Aug 11, 2010
How you put in the radio code when it only has 5 presets
Press each preset the same number of times as the number for the code!
Mar 03, 2017 | Car Audio & Video
Maxtor Basics Desktop 1tb desktop hard drive
is this an external drive or internal?
the answer is based on them.,
if internal drive,
then use BIOS to see if BIOS can see it,
if bios can see, it good, that dont make a drive good
only that it can talk and PNP,
if BIOS can not see it.
1: drive is not plugged in to data and power. (swap cables and ports)
2: or the drives dead. totally, no comms at all.
try all sata power cables
try all sata data ports on MOBO, some are RAID only.
if wInDoZ cant see a drive, no app on earth can either.
always start with bios. that is the first step always.
unless external drive. those are more tricky, ASK !
Sep 30, 2013 | Computers & Internet
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
My iomega media xporter hard drive not being detected by my PC having windows 7?
Try your Iomega drive on another computer to make sure it works. if it works on another computer, then come back to your computer with windows 7 and try different usb ports. Maybe one of your usb ports is bad. If your usb ports are ok, then your drive is not compatible with windows 7.
Go to iomega's website and see if they have an update, patch or driver for Windows 7.
Get online and got to www.google.com In the google search box type: "Iomega Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Windows 7 drivers.
May 30, 2012 | Iomega Media Xporter 160 GB USB Hard Drive
I'm trying to get online for my ps3 and i can't get a wireless connection. so i decided to just do a wired connection from the computers internet connection.how can i do that without messing with the...
1st you need a 4 port router or a modem/router combo 1 that has more than 1 port.
2nd you need to have enough CAT5 cable to get it to 1 of the empty ports on the router.
So basically the way you would hook it up if you are going to use 2 individual components is:
1. Unplug the CAT5 and power supply from your modem the one that goes to your puter.
2. Put the new router under or the side or underneath the modem.
3. The Ethernet cable that comes out of the modem plugs into the corresponding port on the router that doesn't have a number.
4. Now depending on how many ports you have I always put my puter in port 1 and then anything else goes in the other ports, you don't have to do it numerically.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
After few hoiurs is not powering the ports
your USB port on PC is going to sleep - must be windows 7 - 7 has the option to put virtually every device to sleep
Aug 26, 2010 | Dynex 4-Port USB 2.0 Hub
My ScanDisk was working fine in a 7 port hub earlier today. I removed it because I thought I would need to use it on another computer and then realized I wouldn't need to. So then I put it back into the...
Sounds like it is dead sorry to say flash drives are really not a very reliable backup source should always copy to DVD also. Another thing in future you should always use the safely remove hardware option in the bottom right taskbar to remove power from any device before you unplug it. Cheers from Scott please dont forget to vote
Jul 15, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
