The aircon Kelvinator KSC10G turns itself on. I can turn it off using the remote, but it well then turn itself on some apparently random time later
2 Suggested Answers
  • 21 Answers
SOURCE: kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Posted on Jan 15, 2010
Testimonial: "cheers mate problem solved thanks for your expert advice "
My 2015 Chrysler 200 air conditioning won't turn on
Take it to a Aircon specialist for Automotives it may need a recharge . Alternatively the motor serpentine belt may be slipping or not engaging . Sometimes part of the Alternatir system .
Nov 02, 2017 | Chrysler Cars & Trucks
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Logitech Z-5300 Turns off and on by itself
Hi...
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
-Vash_Stepler
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
Aircon no longer responds to remote handset
Open the front again and make sure that the operation selector is set to remote control. If it is, then I suspect that your remote sensor reciever on the aircon unit is bad. It is very simple to replace.
May 06, 2009 | Heating & Cooling
KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
TV just turns itself off
does this happen at night or dark days when lights are on? if so you might be using CFL lights which interer with IR info to the set. it can cause other problems such as random cannel change or no remote responce.
Dec 16, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
