Question about Polaroid Cameras
The letters LL.L appear were the outside temp should be on my digital photo picture frame.
My son came over and fixed it. we then went to a ***** bar and spent that 20 bucks i would have sent to you to fix your own bustedass electronic divice you should stand behind for free. shame on your company!!!!!!!!!!!!!!!!!!!!
Posted on Apr 30, 2008
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
I have a 10" digital [icture frame with no
Instructions Things You'll Need:
  1. Power the camera on. Press and hold both the "Mode" button located on the top right of the camera and the "Trash" icon located on the back left of the camera.
  2. Look for the letters "FOR" to appear on the LCD screen, then release the buttons. After releasing the two buttons, pause for a few seconds then hold them again.
  3. Allow the initialization to complete. Do not press any buttons while the camera is in the formatting process. Once it is done formatting you may resume using the card and the camera.
  4. please comment on this product by saying how helpful it is.raise the thumb up
Dec 20, 2010 | Quantaray 7-Inch Digital Picture Frame -...
Some of my vertical (portrait) photos on my 15" are displaying as horizontal (Landscape). What can I do to fix this?
Have you saved the images that are appearing as Landscape in Portrait?
The frame should display the images as you saved them. Rotate the image in your photo editing program until they appear as Portrait, then save them. This should fix your problem.
Sep 26, 2010 | Sunpak (SDPF-070AW-0US) Digital Picture...
Cannot add pictures says it is write-protected to reset norflash
Check that the correct drive letter is selected in the device list at the top right. Try the Norflash Format button in the bottom right corner of the software. If that does not work, your frame is toast.
Jan 17, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
May 11, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
Will not display photos
"NOT SUPPORT - RECOMMEND - 640 X 480 60HZ" You can find an update for this problem here:
Nov 03, 2008 | Pacific Digital MemoryVue MV-800 Digital...
Cameras Logo
20 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
