Question about Health & Beauty
Why khen amper is my enemy? - Health & Beauty
    Problem Solver:
  • 11 Answers
You shall not offend him like we do FOR God the father
Posted on Aug 07, 2010
List of enemies of spiders
Because they are small, spiders have many enemies. Larger animals, such as birds, toads, lizards and monkeys, hunt them. But they are also used as food by many smaller creatures. Ticks will attach themselves to aspider and eat away at it for a long time while the spidergoes about its business.
Spider Facts - What Are Spiders Afraid Of? - Kidzone.
natural enemies of spiders Google Search
Oct 30, 2017 | Washing Machines
Callofdutyinfinitewarfare
Call of Duty: Infinite Warfare Tips
Use these tips to stay alive in the main campaign, multiplayer and new Zombies in Spaceland game modes.
Use your Thrust Jump to constantly change position around the map. This will make it harder for enemies to draw down on you and take you out.
Be careful when sprinting around corners, as your character makes a ton of noise, and running headfirst into a group of enemies is a sure-fire way to end up dead.
Take your time completing Scenes in Zombies in Spaceland. Make sure you have plenty of ammunition before cleaning out the last of the zombies, and remember to purchase new weapons while you have a down moment.
Always keep an eye on your ammo and be sure to reload whenever you feel the need to. If your magazine doesn’t have enough ammunition in it to take down an enemy, then you shouldn’t head behind enemy lines until after you reload.
Use the slide mechanism to your advantage. Not only is it useful for offensive-based play with Shotguns and SMGs, but it is also a very good move to use when you need to get around a corner and lose an enemy.
Always pay attention to your mini-map. This small area of the screen can alert you to unsuppressed enemy gunshots, as well as ally deaths.
Pay attention to your hit markers. These small icons on the screen are the only definite way you have of telling whether you hit an enemy or not. Pay attention to them as they can be extremely useful in helping you pinpoint an enemy as he tries to flee.
Nov 27, 2016 | Miscellaneous
Who said, "keep your friends close and your enemies closer?
This has often been attributed to Sun Tzu and sometimes to Niccol? Machiavelli or Petrarch, but there are no published sources yet found which predate its use by "Michael Corleone" in The Godfather Part II (1974), written by Mario Puzo & Francis Ford Coppola: "My father taught me many things here - he taught me in this ...
Who said, 'Keep your friends close and your enemies closer?' - Quora
https://www.quora.com/Who-said-Keep-your-friends-close-and-your-enemies-closer
Nov 22, 2016 | Cars & Trucks
How many ampers in 60 watts bulb
Depends on supply voltage
240V.........60/240 = 0.25A
110V.........60/110 = 0.55A
Sep 19, 2013 | YouTube Videos
Back up generator 240 volt output is off balance?
So there is a problem. Where are you measuring voltage?
Say there is L1 - N - L2. Line1 to Neutral is 120 volts, Line2 to Neutral is also 120 volts, Line1 to Line2 is 240 volts. N or Neutral ( the grounded conductor ) is center tap between line 1 and 2.
With this system, the N wire carries the unbalanced load in amperes .
Now we are talking of L1 and L2 and amperes. When L1 and L2 are conducting 10 amperes each, N carries 0 amperes, Line1 and L2 are balanced. When L1 carries 10 amperes and L2 carries 5 amperes, Line1 N carries 5 amperes, the difference of L1 and L2. This is normal.
When there is a problem with a loose connection on N, there is a resistance and will not carry the unbalanced load normally, the voltages will Chang's under load, the problem will worsen with time, a fire hazard, connected loads may burn up from excessive voltage or not work at all.
Bottom line: Make sure the N line ( white wire ) is tight at every connection and inspect for overheating damage. You may have to open the generator connections panel to check there too.
Aug 06, 2017 | Electrical Supplies
What size breaker does the sm-11 require 2-30amp or 2-60 amp?
You will need the 2-60A breakers. 11kw is 11,000 watts. Watts = voltage X Current (amperes) If we take this formula and change it around to calculate amperes it is like this. Amperes = watts / volts amperes = 11000 watts / 240 volts This is 45.8 amperes or let us say 46 amperes. The closest breaker that you have would be a 50 amp breaker 2 pole of course . 2 - 50. If you cannot get a 2 - 50 then a 2-60 is fine. I would run with a #6 copper wire, I would check with local code to verify the wire size in your area. Make sure that the unit is grounded as well. Minimum of a #10 wire, I would also check local codes as well. Enjoy the steam!
Dec 27, 2010 | Steamist 11 KW Steam Unit SM11IM
Is there cheats?
Cheats and Hints :
All primary weapons : Complete the game on Recruit difficulty mode.
Professional Difficulty : Complete the game on Recruit difficulty mode and Contractor.
All secondary and special weapons :
Complete the game on Professional difficulty level. Get extra points unlocking achievements . The game has 47 achievements (10 and 9 in Online extra) for a total of 1250 points. To get the achievements "[Extra]" is necessary to have the SSC Challenge Pack, available at the market.
10 points:
  • Boots on the ground : Finish a game of confrontation even. [Online]
15 points :
  • Complete Mission 3 : Mission 3 completed as Contractor or higher. [Secret]
  • Complete Mission 4 : Mission 4 as Contractor or higher completed. [Secret]
  • Complete Mission 5 : Mission 5 completed as Contractor or higher. [Secret]
  • Complete Mission 6 : Mission 6 completed as Contractor or higher. [Secret]
  • Without Debt : Heal your partner for the first time. Training is not valid.
  • Weapons Specialist : Purchase 3 weapons.
  • That's it. Let's see who's laughing now : Buy weapons pack "pack 8" in a multiplayer ranked match. [Extra] [Online]
20 points:
  • The devil is in the details : Make 20 minor objectives in a ranked match. [Online]
  • Mission failed : Kill 25 Martyrs by shooting against the bombs that are attached to the chest.
  • Toma. Take, take and take : Deletes a total of 50 enemies in melee attacks.
  • Big boom! Big bada boom! : Kill 25 enemies total using rocket launchers.
  • Where to put the eye : Kill 100 enemies total using Sniper Rifles.
  • Let's see, who wants some? : Kill a total of 250 enemies using machine guns.
  • The dead man's hand : Kill a total of 150 enemies using guns.
  • Rain of Lead : Kill a total of 250 enemies using machine guns.
  • Try this : Kill 250 enemies total using Shotguns.
  • Seven six two millimeter : Kill a total of 250 enemies using assault rifles.
  • The beast with two heads : Kill 50 enemies in back to back.
  • Arnold : Eliminates 300 objects in mission 7-8. [Extra]
mcith_army_of_two_10.jpg 25 points:
  • Surviving the game : Make a ranked match without having to Revive once. [Online]
  • Authentic SSC Challenge : Win every stage of a ranked SSC Challenge to three rounds. [Extra] [Online]
  • Victory Challenge in the SSC : Beating a ranked SSC Challenge. [Extra] [Online]
  • Gunman SSC Challenge : Get a 75% accuracy after a ranked SSC Challenge to three rounds. [Extra] [Online]
  • SSC Challenge barrels : Remove 500 barrels in ranked matches SSC Challenge. [Extra] [Online]
  • I want to be cleaner : The final blow to Dalton is a shot in the head with a .44 pistol Model 29 tuned. [Extra]
30 points:
  • If it bleeds, it can die : Kill 25 with heavy armor.
  • Medical field : Drag your partner and heal him 25 times.
  • Riots : Kill 50 enemies in total using a riot shield in cooperative mode.
  • Mission 1 complete : Mission 1 completed as Contractor or higher. [Secret].
  • Complete Mission 2 : Mission 2 completed as Contractor or higher. [Secret]
  • Corridor : Eliminate 75 enemies stealthily mode Annihilation.
  • L'Abattoir : Kill 100 enemies in way of Annihilation.
  • Stone wall : Kill 30 enemies using melee attack riot shield.
  • I'll kill you last, promised : Kill Dalton in less than 40 seconds. [Extra]
  • Complete Mission 7 : Mission 7 completed as Contractor or higher. [Secret] [Extra]
  • Complete Mission 8 : Mission 8 completed as Contractor or higher. [Secret] [Extra]
35 points:
  • A weapon is sufficient : Ends in a ranked match without purchasing additional weapons. [Online]
  • Four eyes are better than one : Kill 5 enemies using sniper tactics cooperatives.
  • My virtual friend : Make all missions with an AI-controlled partner.
40 points
  • Pension Plan : Get one billion dollars in total in ranked matches. [Online]
  • If I were rich : Get a million dollars in total in campaign mode.
  • My kit! : Collect the briefcases with information throughout the game.
45 points :
  • Fear, the murderer of the mind : Spend 1 full minute at maximum aggression.
  • Hello to my little friends : Get the following: MP7, M134, DAO-X Protecta, MGL MK-X, and M107 Light Fifty.
50 points :
  • A man of many masks : Buy all variants of mask.
  • PMC elite : Make all missions as a professional.
  • Unlock big heads : Finish the campaign occasional difficulty
  • Unlock unlimited ammunition : Finish the campaign occasional difficulty
try these
Apr 30, 2010 | EA Canada Army Of Two The 40th Day for PS3
Ampers for Sony CDX-S2210S CD
If the in-line fuse from the car installation is still attached, check the fuse rating; it will state a figure that is in excess of the demand of the stereo. In other words, if the fuse has 10A on it, it was chosen to fail at currents higher than that. If this unit is only a CD player (no amplifier built-in), it will not likely draw in excess of 2 amperes and probably not over 1 ampere.
If you have no documentation, you can download what you need here:
Sony manuals for your unit
Nov 15, 2009 | Sony CDX-S2210 CD Player
I lost the adapter so i need to noe what is the
The ampere is the SI unit of electric current. The ampere, in practice often shortened to amp, is an SI base unit, and is named after André-Marie Ampère, one of the main discoverers of electromagnetism.
In practical terms, the ampere is a measure of the amount of electric charge passing a point per unit time.
Jul 27, 2009 | Creative Labs Inspire 4400 Computer...
God of war 2: challenge of the titans mode
CHALLENGE 1 - BLIND FURY
BONUS: SHATTER TWO ENEMIES
For this battle, equip Euryale's head and freeze the Cyclops first (so
he doesn't distract you). Freeze the other two enemies and then shatter
them to get the bonus. Now attack the Cyclops and grab that eye!
NOTE: You can replay this challenge to gain more Cyclops Eyes! Gain
20 eyes to unlock a special costume!
CHALLENGE 2 - DEATH FROM ABOVE
BONUS: KILL 15 ENEMIES IN THE AIR
The best weapon to use is either the Athena Blades or the Spear Of
Destiny. For the spear, use the Triangle + Triangle combo to toss an
enemy into the air and attack them. Try to avoid fighting the bigger
enemies and focus on the smaller ones.
You can only toss the satyrs, soldiers, and gorgons into the air! You
can't fling the berserkers or minotaurs into the air so don't even try!
CHALLENGE 3 - GORGON GRAVEYARD
BONUS: SHATTER 35 ENEMIES
Equip the Barbarian hammer and Euryale's head. Use the Super Gaze
attack (L2 Button + Triangle) on each enemy and then pound on them with
a hard attack with the hammer to shatter them. Use the Fleece to defend
from the other gorgons!
CHALLENGE 4 - PROTECT THE WEAK
BONUS: KEEP TRANSLATOR'S HEALTH ABOVE 50%
This is a very lengthy challenge. The translator sits on a glowing
circle. Every 30-35 seconds, the circle will move to a different area
and you MUST move him towards the circle's new location or he will
start to lose health. As for the enemies, abuse the Amulet and pound
all of them with your hardest combos until the game says you are done.
CHALLENGE 5 - REAP THE REWARDS
BONUS: COLLECT OVER 600 ORBS
CHALLENGE 6 - SURVIVAL OF THE FITTEST
This is also a very lengthy challenge. Your health will continually
decrease throughout the challenge and you gotta keep the dead bodies
flowing (sort of like Shinobi). Survive the onslaught to complete the
challenge!
CHALLENGE 7 - PERFECTION IS DIVINE
Hopefully you've perfected the art of countering with the Fleece
because there's no other way to complete this challenge! Keep your
distance from the petrified minotaur and pound combos onto the other
enemies. You MUST kill the priests or else the challenge won't end!
Once all the other enemies are gone, deal with the minotaur and kill
him with a fatality!
Jul 20, 2008 | Sony God of War 2
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
