Question about Sun 501-4366 X1034A PCI Quad FastEthernet (QFE/P) - REFURBISHED (5014366REF) Network Adapter
There are no windows drivers for SUN x1034a Quad 4-port PCI network card.. thus it cannot be used in windows. But does anyone know if it will work in a linux virtual machine hosted in windows 7 x64 ?
3 Suggested Answers
vincent721
  • 240 Answers
SOURCE: X1034A PCI Quad FastEthernet driver for Windows 2003
NIC card driver is for Sun and Linux only
try to find the Chipset of your NIC you might found the windows driver for it. google it.
Goodluck
Posted on Mar 20, 2009
bronk50
  • 27725 Answers
SOURCE: how to check pci sun
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers if you don't have a disk with the drivers you have to download them
http://download.cnet.com/matrox-millennium-ii-agp/3000-2108_4-10028803.html
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
Posted on Aug 31, 2011
Sony vaio vpcy21s1e/p
simple communications controller is likely a modem, sound card, or network card. If your sound was not working, you would know, and similarly with your network. So try sound card drivers next.
Feb 03, 2012 | Computers & Internet
Good day. Need a driver for SMC Sun PCI Quad Fast
Please be informed that any Driver Software depends upon its Hardware make and Operating System support. You need to know all these information to get started working with that particular hardware. You can find the driver software inside the disc provided to you at the time of purchase.
As per your query i have checked a lot of technical sites and even Sun microsystems,but I found that this network device can not be installed in a windows platform as this only supports Solaris Operating System.Please find the detail here http://docs.oracle.com/cd/E19113-01/quad.fast.sbus/804-6116-10/804-6116-10.pdf
The Sun Quad FastEthernet SBus adapter is supported on systems running the Solaris operating environment, versions 2.4, 2.5, 2.5.1, 2.5.1 Hardware releases, and 2.6. The Sun Quad FastEthernet PCI adapter is only supported on systems running the Solaris 2.5.1 Hardware releases and Solaris 2.6.
Nov 24, 2011 | SMC Sun PCI Quad Fast Ethernet Card (p/n...
Hey, um, I have a Dell Demension 3000 and I want to replace the sound card on it. I have a couple of questions: 1. Can I just get any sound card? 2. I know I install it in the PCI slot, but where is that...
1. Almost all sound cards are standardized, and there are drivers for all major operating systems (windows, mac, and linux). After installing the card, you will need to install the correct driver to make it work, (on a pc, it is likely the driver will be installed automatically.
2. PCI slots look like this - http://www.google.com/search?q=pci+slot&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1440&bih=802 - They are all on the motherboard, and a few of them will already be in use. Your monitor cable port is part of a card in a pci slot and your network ports are part of a card connected to a pci slot.
3. All your software settings are stored on your hard drive, if you don't swap out the harddrive, then none of your settings will be lost.
Jul 02, 2011 | Dell Dimension 3000 PC Desktop
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a...
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Mar 13, 2011 | Promise FastTrak TX4650 4 Port SAS RAID...
Just installed xp for a friend on an old ibm netvista 6794 NZU pc. Went to ibm website but can not find the motherboard or chipset drivers to allow this pc to acess the internet. Can anyone help please. ...
It's a big pain when you dont have the right driver. but try this:
1. download and install the Windows Service Pack 3 (XP SP 3) in the computer and check if it works.
and how are you trying to connect to the internet? you might just want to put in an extra PCI network card, if you want to use the broadband or if you need the usb ports to work, try a PCI USB card instead.
either ways, make sure you have installed SP3 in that computer.
cheers!
Nov 17, 2010 | Computers & Internet
Hello! I am loooking for a network card to a 9 year old Compac 8455EA, The prblem is that I bought a network card without looking how it is done in this computer. It is an integrated card containing...
Not sure what you are looking for. You can get a simple network card
BELKIN F5D5000 10/ 100Mbps PCI Desktop Network Card 1 x RJ45 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16833314101&cm_re=network_card-_-33-314-101-_-Product
From what I can tell, your computer uses PCI slots so .... you want to make sure you get a PCI network card and that it comes with drivers for your operating system.
Mar 12, 2010 | Computers & Internet
Goodluck
Mar 20, 2009 | HP Computers & Internet
Laptop ip stuck on same nr
You can release and renew the IP.
Go to command prompt and enter ipconfig /release, press enter
and then type ipconfig /renew, press enter
see if it works.
(note:there is a space between ipconfig and the /)
Jan 27, 2009 | Sun 501-4366 X1034A PCI Quad FastEthernet...
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
PCI PARALLEL CARD WINDOWS VISTA X64
There are know compatibility and driver problems with Vista. Please visit the Microsoft update website for updates and driver issues.
Feb 20, 2008 | Televison & Video
Computers & Internet Logo
989 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
