Question about Sharp DVRW250 DVD Players
Can i record vhs to dvd on this player? can i down
Can i record vhs to dvd on this player? can i down load operating instuctions anywhere?
Put a dvd-r or dvd-rw in the device, switch to vdeo mode put in the video and play it, as soon as you want to record press the dubbing button on the remote
Posted on Dec 30, 2010
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
I have a Toshiba DVD Video Recorder. How do I record from a VHS to a DVD?
For a toshiba DVD player there should be a s-video input. For a vhs you must have a vhs player that has a component/s-video output. Hook up the vhs player to the dvd recorder using an s-video cable and press play on the vhs player. Then press record on the dvd recorder.
Feb 28, 2011 | Toshiba Televison & Video
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
I want to put my VHS movies onto DVD's.
It will copy VHS to DVD. Provided that it is a home movie and not a copywritten movie from the store.
Jan 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I want to transfer from vhs to dvd. Video tape is protected.
You can copy VHS tapes that cannot be done on standard equipment. You can buy EZGRABBER to down load VHS tapes to your hard drive, then use a program likePower Produucer to go from your hard drive to a recordable DVD unit if you have one installed in your computer
Apr 21, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Cannot play dvd-r copies on other dvd players
Did you finalize the disk after recording? see manual for directions.
Jul 06, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sharp DVRW250 DVD Players Logo
138 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
