Question about Fujitsu Siemens 3815 FA-M (White) 15" LCD Monitor
My monitor fujitsu siemens has OSD locked,what can i do? please help!
Falcon4
  • 5 Answers
SOURCE: OSD Lock
Try holding Menu (or the similar button on yours) while turning the monitor on. That fixed mine! I was trying to get into a service menu and seem to have locked myself out... after several failed Googles (including this one), I ended up just toying with buttons again.
Posted on May 05, 2008
yboyandrei
  • 828 Answers
SOURCE: Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Aug 07, 2009
  • 732 Answers
SOURCE: bulb has blown in my 17
janine_13, What makes you think that you can install one even if you can get one of those "cold-cathode-fluorescent-lamps" ! They are not some sort of screw-in lamps. They are glued in with silicone RTV compound and will need to be cut out and cleaned of all excess old silicone before the replacement will be installed. Once clean, you slide in the new one and apply new silicone RTV to hold the new lamp in place. Are you really sure you want to do that? Are you sure that is the real problem? 12fixlouie you can check with www.lcdparts.net or other places on web to find more info.
Posted on Nov 11, 2009
SOURCE: Viewsonic E72f+ OSD Locked
press and hold the 2 button... the button which has named 2 on it... for some seconds... maybe 10...
Posted on Jan 27, 2010
budmrtn
  • 11361 Answers
SOURCE: how to remove osd lock in aoc f19 monitor
Please see my profile on how to unlock the monitors.
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Posted on Apr 29, 2010
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
OSD locked
OSD MAIN CONTROLS REMAIN UNLOCKED ON MONITOR 170A PHILIPS SERIAL NO AU 015240
Nov 24, 2012 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Osd locked on screen Fujitsu Siemens
holding down the select/menu button and pushing the power button and keep holding the select button down until the menu appears and hey presto, one unlocked osd!
Repeat the process to lock it again.
http://forum.ts.fujitsu.com/forum/viewtopic.php?f=100&t=30092
hope this helps
Sep 06, 2012 | Computers & Internet
I press menu button and it shows OSD Locked instead of giving menu. How to remove this prob?
Hold down the select or menu button and press the power button keep holding down the select button until the menu appears this should unlock your osd :)
Feb 08, 2012 | Fujitsu Siemens Siemens Basic Line B17-1...
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
I have a monitor that was given to me.
OSD Lock Settings
You have the option of using the OSD Lock feature to prevent current image
adjustments from being changed.
• OSD Lock: Press and hold [1] and [J]
for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and [J]
again for 10 seconds.
May 03, 2008 | Philips Brilliance 109S Monitor
Fujitsu Siemens 3815 FA-M (White) 15" LCD Monitor Logo
3,452 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
