Question about Compaq Presario M2000 Notebook
Red line on my screen
Please help me how to solve the red line on my screen, it runs horizontally right down from top to bottom
  • Donald Burr
    Donald Burr May 11, 2010
    Does this line show even during the boot up process, or just when Windows starts? If its during the entire power on process, you need to have the laptop serviced. There is a hardware issue that is causing it, and you would need to do some seriou diagnostics to determine if its the Screen or System board. If its not happening during the boot up then we can see what we can do for you. Please let me know .Thanks ///D
    Sergeant:
    Champion:
  • 256 Answers
Hi
You need to replace screen not other choose.
Thanks
Posted on Apr 27, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Thin red horizontal lines across screen
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Compaq Presario M2000 Notebook Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
