Question about Sony PlayStation® 3 (80GB) Console
After a weekend at a freinds house using his smart flatscreen tv and using a hdmi lead when i plug it back into my tv using a scart lead nothing appears on the screen please help
    President:
  • 1,139 Answers
Ok, you need to hold the power button down for 5 seconds until it beeps once, this will revert back to standard definition.
Hope this helps
Posted on Aug 07, 2010
My Samsung smart tv wont allow my Sagem DTR 6400T/6700T to operate/initialise when connected with HDMI cable. No scart on tv.
if the resolution of the sagem is too low it will not work or reset your sagem or switch the picture mode from scart to hdmi
Mar 27, 2018 | Samsung Televison & Video
Got a double picture on my TV which is going through a bt u view box
If you are not getting a tidy pic first thing I would check or change is scart lead make sure they are firmly in back of TV and your viewing box if so try another scart lead, the thicker the scart lead is the better they are apparently. Or if your using hdmi lead instead of scart try another hdmi port at back of TV as these ports tend to break easy in TV as they break off the mother board.
Apr 12, 2016 | Televison & Video
Tuning in skyview box to bush television
hi, how is it set up, are you using a scart lead or a hdmi lead if your using a scart lead you need to select av 1 or ext1 if your using hdmi lead you need to select hdmi 1, come back to me if your still having problems thanks.
regards
shaun
Apr 06, 2014 | Bush Industries IDLCD15W008HD LCD TV
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Feb 02, 2008 | Philips HTS-6500/37 System
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
