Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
Most of the time the TV does not come on when I push the power button. The red light flashes.
How do I fix it
Posted on Sep 06, 2010
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at partstore.com or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Aug 27, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
