Question about Nokia 1100
I removed the network ic and had a jumper but it has no network i tried to find manually but did not get network and even i changed a battery adapter also but no use
  • Nokia Master
  • 2,148 Answers
If the jumper you have done is correct then the problem occur from CPU. So try to give some light heat or replace .Good luck
Posted on Aug 07, 2010
Battery is dead. Once jumped n the jumper cables are removed it dies again. My vehicle is a 02 Buick lasabre
Once jumped n the jumper cables are removed it dies again. I would think it's not charging , alternator problem maybe .Is the battery light lit on the instrument cluster ?
May 08, 2018 | Cars & Trucks
How to bypass a BIOS set up password on the notebook
Remove all power sources, ac adapter and main battery if you have one. Then disconnect RTC battery for 30 seconds. It is located under the tear shaped cover on bottom of computer. Reconnect RTC battery and ac adapter but DO NOT PUT BACK THE MAIN BATTERY until you have reset the date and time.
Please rate & vote , if you like solution..
Thanks
Mar 14, 2011 | Compaq Armada M300 Notebook
I have nokia 2680s network problem & i dont have network ic i want 100% jumper of netwok ic sucess
nokia 2680s no network so change network Ic but notwork ic so network ic jamparing solution in picture
Dec 25, 2010 | Nokia 2680 Slide Cell Phone
Plz mujhe nokia n73 ke network problems jumper solution dijiye
sir
nokia n73 ka pf ic remove karke jumper mar rha hu to no network fond a rha hai
plz help me
Sep 19, 2010 | Nokia N73 Cellular Phone
I forgot BIOS password for SONY PCG-GRX520
The best way for the Sony is to remove the cmos battery for at least 30 minutes. Remove the main laptop battery and leave it out. Make sure the power adapter is not attached. The cmos battery can be reached after removing the keyboard and is attached to the motherboard vis a small cable. If you have a "jumper" that come equipped on hard drives to jump the pins on the back, you can "short" the pin connections on the cmos battery socket, power the laptop up using the ac adapter and letting the computer go through the bootup process. When this happens power the laptop back down, take the jumper off and replace the cmos battery. Power back on with just the ac adapter and boot the computer. If the laptop still askes for a bios password just hit enter and it should allow you to log in. Once in go into the bios and reset the date and time. Once that is done power down and replace the main battery. Reboot the laptop and let Windows load.
Nov 18, 2009 | Sony VAIO GRX520 Notebook
ZOOM H2 LOCKED UP DURING A RECORDING SESSION AND WILL NOT COME BACK ON...TRIED AC ADAPTER EVEN. NEW BATTERIES....NEVER BEEN DROPPED. hAS WORKED FOR 6 MONTH NO PROBLEMS!
You have an IC (Integrated Circuit) that has shut off internally. Try complete power down (remove any electrical power - includes any internal batteries) overnight. Then try again. If this doesn't work, it's an IC malfunction.
Jun 20, 2009 | Electronics - Others
URGENT! Jumper setting (J4 jumper)
Hi, You can try this
1. Turn off the laptop
2. Disconnect AC adapter
3. Remove battery pack, and remove the keyboard
4. Remove the battery (located underneath the keyboard, the red/white wire)
5. Leave it for about 30 - 60 mins.
6. Reconnect the battery and reassemble the laptop
7. Reconnect AC adapter (Don't put in the battery pack yet!)
8. Turn on the computer and press F10 to enter the BIOS
9. Set the new BIOS password and save all settings.
10. Turn off the laptop and reinsert the battery
If this does not work you can try and check out a manual for your laptop here.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1847703
Mar 26, 2009 | HP Compaq nc6400 Notebook
Magnavox MPD850 DVD Player Doesn't turn ON
Many people buy electronics and never read the manual.
The first thing to do before operating an electronic device is to
read the manual, is for the best. I have had this unit for two years now
and have no problems with it. The most commond mistake people make
with this portable DVD is that they plug in the lighter without removing
the battery. You can't charge the battery with the lighter adapter and
you must remove the battery before you turn it on.
Dec 18, 2007 | Philips Magnavox MPD845
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
Addtron AE-200 network card - jumpers setting
hi check this out: http://groups.google.com/groups/search?hl=iw&q=Addtron+AE+200+jumper++settings&qt_s=%D7%97%D7%99%D7%A4%D7%95%D7%A9 good luck
Apr 25, 2006 | Addtron AE 200 Network Adapter
Nokia 1100 Logo
372 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
