Question about FrancisFrancis! X1 Espresso Machine
The clear tube in our machine has grown green algae, since it doesn't detach is there any other way to clean it?
Remove algae from GV7070 water tank
Chlorine/bleach - read carefull the instruktion on the back og the bottle. DO NOT USE IT without thinning it with water in the correct dosis! Let it rest til everything is dead. Dont get it in the machine it will be damaged. Do not boil it in the machine! only for use in the watertank. Clean carefully.
May 21, 2014 | Tefal GV7070 Iron
How clear a/c drain tube
one of the most easy questions yet. love em.
the pipe is packed
i jams a stuck or wire up it and un pack it. at arms distance , might stink. and be green algae there.
Jan 04, 2014 | 2009 Toyota RAV4 4x4
Sand filter gauge reads zero. have good circulation, however the pool is still green and not clearing up.
Green could be metal or algae. Remove algae with algae removing product. Remove metal with a sequestering agent. I suggest you try the metal first. Follow all package directions. Run your filter 24/7 until this clears up. This may take up to a week. You may want to use a flocking agent in your sand filter. Is your gauge broken? Are you CERTAIN you have water circulation? Have you checked your sand in your filter? Your impeller is intact and working?
Let me know about your progress.
Oct 19, 2011 | Hayward SAND FILTER, PRO SERIES
After a few months use there is a green algae like growing in the bottom of the water container. I am using filtered water. Is this normal and Is there a solution?
Using filter water of course helps keep things clean and so forth. To help solve this algae problem when you descale and clean machine use vinegar and that should help from algae building up. Thanks Mike
Sep 14, 2011 | Keurig Elite B40 Coffee Maker
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Apr 10, 2011 | Tetra Green Free Uv - 2 Clarifier - 18...
Algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
Apr 04, 2009 | Saeco Incanto Classic Espresso Machine
I have a similar problem, but the blue fluid in my pth5498 has turned yellow. I tried the website listed and it did not define if the "coolant" was green, blue or red. Where do I find the blue fluid? Do...
All the coolant is the same.It is clear . After you remove the old coolant clean the face of the tube to remove the algae -like contaminate then install new fluid.
Feb 27, 2009 | Akai PTH5498 54" Rear Projection...
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Algae in water tank?
Try to clean it with soap, if you are careful you can bend in the edge and take it off.
Use some glue on it when you put it back.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
FrancisFrancis! X1 Espresso Machine Logo
21 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
