Question about Cameras
Memory card when i put my memory card in my camera it wont let me take pictures or delete any it just says "card protected", but when i take my card out it will take pictures
  • 41 Answers
From your description it sounds like your card is full. Are you able to download to your computer? If you are able to do that then try deleting individual photos on the card using the Computer to do so. If you can achieve that then try to Re-format the card back in your Camera. Hope this helps you.
Posted on Apr 28, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Protected momery card
If you did not remove the memory card before, it could be there is a bad contact on the memory card or in the camera. It also could mean your card is full. (you should delete some pictures) First put the pictures on the computer or another memory, like external hard drive, or somewhere in the cloud.
If you recently had your memory card out, it could be you accidentally switched it to lock. See the picture how the switch on the SD card should be. The 64GB card is unlocked, the 32GB card is locked. Make sure your switch is up like on the picture.58575d9b-f54f-431e-b178-18861b326f77.jpg
Jan 26, 2014 | FUJIFILM FinePix JV200 / JV205 Digital...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
WRITE PROTECT ON WONT LET ME REMOVE OR DELETE PICTURES OR EVEN TAKE PICTURES
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 15, 2011 | General Electric A835 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
I have a digital camera and the model is C1033 , i put a san disc drive card in with a memory card in the san disc and on christmas day it worked fine, a few days later i couldnt take a picture and it says...
Sound like the card is corrupted. Take it out and try in a card reader, search for image recovery software if you can't read the card properly. When you've finished trying to get the images off the card format the card and retry in the camera.
Jan 02, 2011 | GE C1033 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
Why is my memory card write protected
Hello there,
You cannot delete pictures if the memory card inside your camera is "Write Protecte". What you need to do to unprotect it is to turn off the camera and take out your memory card. You will find a small 'tab' that might be pulled up or down. If it is pulled down, you can slide it up or vice versa. Put it back inside the camera and start deleting pictures.
Hope this helps you. Good luck!
Oct 02, 2009 | Nikon Coolpix 4500 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Cameras Logo
252 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
