Question about Vacuums
Leaking out of hole
Hi
I went to fill my Hoover Steam Vac and the hole is open at bottom. I went to machine and a black post with a spring on it (reminds me of inside on a pen) was just lying there. I tried to figure out how to attach it back, but I wonder if another part is missing. There is a rubber gasket on the base that it fits onto, but it doen't remove.
    President:
  • 1,673 Answers
That is the valve asm. to release the water when it is depressed when you squeeze the trigger. Best to replace it, usually it comes with a new seal, hard insert, spring and valve. Check under neath the seal to make sure that the tank is ok, if a hole or crack, then replace the tank.
Posted on Apr 28, 2008
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=641300
Generic problem for all Vacuums
Posted by w_brennan on Jun 02, 2008
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a problem with the bottle you fill with detergent ex: this bottle is separate from the main clean water tank. THE PROBLEM: The little plastic part that goes in the bottom of the bottle has an "O" ring ex: cone shaped with a spring.....it keeps falling out. Can you supply a part number for this component? The bottle has a number ex:36778-002. Thanks...Linda (504) 888-2120.
E-mail address: w_brennan@bellsouth.net
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hover SteamVac V2 with Auto Rinse feature. I would suggest because the model 3 and the serial 3 have been worn of the machine to contact your local vac dealer in your area and or the Hoover Factory Service or the Hoover Website for the Factory Model #, but the part that you are requesting is not very expensive and can be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
