I have an LG WM-12230FB and it is showing error code 5E. there is no reference to this code in the manual. Any ideas?? Many Thanks
  • craigT Apr 28, 2008
    Thank you for the information.
    I have a couple of follow-up questions:
    What are the 3 sensors, they appear to read like diodes?
    Do you know what the reading should be for each pin?
    Do you think the damage to one of them would cause the problem I have with the SE code?
    Do you think this is fixable, or do I need a new part?
    I have located a motor approx £100, but the sensor does not seem to be available separately, do you know of anywhere I can get just the sensor?
    I have attached some images also.
    Many Thanks.
    Guru:
  • 1,342 Answers
The error is most likely SE and is caused by a faulty sensor in the motor.
Click here for steps to repair it
Posted on Apr 27, 2008
  • Georgia B
    Georgia B Apr 29, 2008
    The sensors control the rotation on the motor. I do not have the output specifications readily available. Since the part is plastic I don't think it would be worth trying to repair. Best bet would probably be to get a new or used motor.
  • 758 Answers
Error 5e means to check the debris filter...
I hope that helps..
For all other errors you can check this error guide
http://erms.samsungelectronics.com/customer/ie/jsp/faqs/faqs_view.jsp?SITE_ID=31&PG_ID=4&AT_ID=84289&PROD_SUB_ID=59
Please rate accordingly
Thank You
Computerrep
    Genius:
  • 3,422 Answers
HI,
5E = Clean the debris filter. Make sure the drainage hose is installed correctly.
Goodluck,
Please don't forget to rate the solution
  • 3,037 Answers
I believe that when 5e is displayed it means to check the debris filter which is usually located at the bottom right hand side of washer and don't forget to drain the washer first!
Also, is there anything that would suggest the machine is otherwise not running properly?
I would also try to reset it by unplugging it or tripping the circuit breaker.
Let me know if you need more help and I would be glad to assist you further with this.
thank you
  • Benjamin Patri
    Benjamin Patri Apr 28, 2008
    If anyone could sell the individual sensor, I believe LG would, try calling them at 1-800-243-0000
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
Lost plastic bung for drain hose
Try ebay - great for bits like that at much lower rates than through technical support!
Dec 28, 2011 | LG WM-12230FB Front Load Washer
My washer wont rinse or spin SE keeps coming on
Hello
LG washing machine error code SE indicates a "motor fault.
You can try resetting it by unpluging the unit for 3 min and see if it clears.
If not, it s going to need service.
Apr 08, 2011 | LG WM-12230FB Front Load Washer
Can you please advise what CL means on our washing machine (LG WD1049C)
CL usually stands for child lock , look for a button indicating LOCK or child safety maybe a childs face etc. once you locate this button push for 3-6 seconds to unlock.
Jan 12, 2011 | LG WM-12230FB Front Load Washer
Error code 5E
LG WM-11150 FB LG -WASH MACHINE SHOW ME THAT I HAVE ERROR 5E.COULD YOU EXPLAIN ME WHAT I MUST DOING WITH THIS?MANY THANKS FOR YOUR HELP
Nov 02, 2010 | LG Washing Machines
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
Error message UE is displayed and the machine has stopped
UE means unbalanced load. This happens when the load is too small, or the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Jun 16, 2009 | LG WM-12230FB Front Load Washer
LG WM 12230FB WASHING MACHINE
the belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Jul 06, 2008 | LG WM-2277HW Front Load Washer
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
Washing Machines Logo
348 people viewed this question
Top Washing Machines Experts
