Question about Microsoft Windows XP Professional SP2
HOW TO INSTALL WINDOWS XP ON SONY VAIO VGN-UX17GP DURING INSTALLATION STOP 0x0000007B (0xF789E524, 0xC0000034, 0x00000000, 0x00000000) ERROR COMES
sandrew
  • 2961 Answers
SOURCE: i need xp driver
Just a second; you have Vista installed on your notebook but want an XP driver???? Can you expand a little please
Posted on Aug 22, 2007
osborne382
  • 306 Answers
SOURCE: sony vaio vgn-fs415m
You can down load it from www.mininova.org. You'll need to use a bittorrent for downloading. Or you can do a search online to purchase windows xp sp2.
Posted on Nov 10, 2007
migregorio
  • 42 Answers
SOURCE: Windows XP drivers for Sony VAIO Laptop
There is no easy answer for this type of question, unfortunately. The best I can do is offer some advice. While installing XP is always possible, and most of the time preferred by the user, not all of the hardware will work every time with every computer. That's just a disclaimer. I think this thread may be useful to you: http://forum.notebookreview.com/showthread.php?t=128804
Posted on Apr 12, 2008
pcblogger
  • 44 Answers
SOURCE: stop error
Visit this post on microsoft to resolve your problem.Your RAM may be the cause of the error.
Posted on Aug 22, 2008
s_4u_11
  • 535 Answers
SOURCE: i need an windows xp drivers for sony vaio
here is link for u download from here
http://www.sony-asia.com/support/download/226644/product/vgn-nr17g/modelfirst?subpage=detail
Posted on Aug 19, 2009
My laptop sony vaio vgn c25g is refusing to install windows 7 but if i put windows 8.1 its doing.. what could be the problem
a number of error during installation?
The installer can not find the hard disk?
Download drivers for windows 7
Dec 12, 2016 | Sony Computers & Internet
Stop:0x0000007b
Hi Jefferson,
  1. Did you just install or make a change to a hard drive controller? If so, there's a good chance that the change you made caused the STOP 0x0000007B error.
    Undo the change and test for the 0x7B blue screen error.
    Depending on what changes you made, some solutions might include:
  2. Verify that the SCSI chain is correctly terminated, assuming you're using SCSI hard drives in your computer. Incorrect SCSI termination has been known to cause STOP 0x0000007B errors.
    Note: Most home computers don't utilize SCSI hard drives.
  3. Verify that the hard drive is properly installed. An improperly installed hard drive could cause STOP 0x0000007B errors and other issues.
  4. Verify that the hard drive is configured properly in BIOS. The STOP 0x0000007B error could occur if the hard drive settings in BIOS are incorrect.
  5. Scan your computer for viruses. Certain viruses that infect the master boot record (MBR) or boot sector can cause STOP 0x0000007B errors.
    Important: Make sure your virus scanning software is updated and configured to scan the MBR and boot sector.
  6. Update the drivers for your hard drive controller. If the drivers to your hard drive controller are outdated, incorrect, or corrupted then the STOP 0x0000007B error will likely occur.
    Note: If the STOP 0x0000007B error occurs during the Windows setup process and you suspect that the reason is driver related, be sure to install the latest hard drive controller driver from the manufacturer for use during the installation of the operating system.
    Note: This is a likely solution if the second hexadecimal number after the STOP code is 0xC0000034.
  7. Change the SATA mode in BIOS to IDE mode. Disabling some of the advanced features of SATA drives in BIOS could stop the STOP 0x0000007B error from showing up, especially if you're seeing it in Windows XP or during a Windows XP installation.
    Note: Depending on your BIOS make and version, SATA mode may be referred to as AHCI mode and IDE mode may be referred to as either Legacy, ATA, or Compatibility Mode.
    Note: While not a common solution, you may also want to try the reverse - see if IDE mode is selected in BIOS and if so change it to AHCI, especially if you see the STOP 0x0000007B error in Windows 8, Windows 7, or Windows Vista.
  8. Run chkdsk on your hard drive. If the boot volume is corrupted, the chkdsk command might repair the corruption.
    Important: You'll likely have to run chkdsk from the Recovery Console.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC0000032.
  9. Perform an extensive test of your hard drive. If your hard drive has a physical problem, one very likely situation is the STOP 0x0000007B error you're seeing.
    Replace the hard drive if the diagnostics you complete suggest that there is a hardware problem with the drive.
  10. Run the fixmbr command to create a new master boot record. A corrupted master boot record might be causing your STOP 0x0000007B error.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC000000E.
  11. Clear the CMOS. Sometimes the STOP 0x0000007B error is caused by a BIOS memory issue. Clearing the CMOS could solve that problem.
  12. Update your BIOS. In some situations, an outdated BIOS could cause a STOP 0x0000007B error due to incompatibilities with a hard drive controller.
  13. Update the hard drive controller's firmware if possible. Just as with the BIOS in the previous step, an incompatibility could be causing the 0x7B error and a firmware update from the manufacturer may correct the problem.
  14. Repair your Windows installation. If you've just replaced the motherboard in a computer without reinstalling Windows then this will likely fix your problem.
    Note: Sometimes a Windows repair will not fix a STOP 0x0000007B error. In those cases, a clean installation of Windows should do the trick.
    If you haven't just replaced your motherboard, a Windows reinstall probably will not fix your STOP 0x7B issue.
Hope this helps,
If you need further assistance please get back in touch and i'll see what else we can do.
Thanks,
Gary
Oct 17, 2013 | Toshiba Computers & Internet
Stop error on sony vaio vgn-nw235f
There are multiple possible reasons for your problem:
1. virus
2. hard-drive malfunctions
3. OS malfunctions
4. memory failure
Try to install an antivirus and do a deep scan. You should pay attention to a boot sector virus.
If this doesn't help, do a back-up of your data, format your hard disk and re-install a fresh OS.
If this doesn't help either, try changing the RAM memory.
If that doesn't help either, it means your hard disk's boot sector is damaged. There are solutions for this too, but I think there is a big chance you won't get to this point.
Aug 07, 2012 | Sony NW Series VAIO VGN-NW235F PC Notebook
Hello, i have sony vaio VPCEB46FG laptop & i have
You're getting what's known as the 'blue screen of death' as some may call it.
This happens for various reasons, but usually occurs when Windows encounters a conflict with a hardware component in your laptop. When you try to install XP, are you doing so as a secondary operating system (dual OS boot) or are you trying to install it over Windows 7?
If you are installing XP over Windows 7, try doing a full format during setup instead of the usual quick setup. This may take some time, possibly requiring you to format the hard drive overnight but it may well solve any 'blue screen' issues you're experiencing.
Let me know if I can assist any further.
Best wishes,
Graemevm
May 31, 2011 | Sony Computers & Internet
Hello, i have sony vaio VPCEB46FG laptop & i have windows 7 64bit operating system & i want to install windows XP 32 bit but im getting following error "a problem has been detected and...
It is required to install the hard disk SATA drivers in the computer first. Download and extract the SATA drivers in a floppy drive, hard drive or CD on a different computer. Then, retsrt the computer by having the Windows XP disc inserted and beging the setup. During the setup process press the F6 key and enter>enter and then install the SATA drivers. Then, continue with the further setup process.
http://www.sony.co.in/support/product/VPCEB46FG
Select Windows XP Operating System and install the SATA drivers. Once, the SATA drivers are successfully installed you can continue with the further setup process with out errors.
You can also view a complete set of instructions on downgrading to the Windows XP Operating System and installing the SATA drivers.
http://esupport.sony.com/US/perl/support-info.pl?info_id=337#
May 31, 2011 | Sony VAIO VGN-S460 Notebook
Win xp is not installed on sony vgn-cs17g laptop
Hi, probably the cd may be corrupted or first u format the previous installed advanced os using that os installation disc and then install xp.because if u r using windows vista or seven it won roll back to previous versions. Another option is you can have two os on two drives
Regards, sathyamoorthy
Nov 15, 2010 | Sony VAIO CS VGNCS215JP
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
Sony Vaio XP Downgradation Wireless problem
Same Problem I am facing too. I am also having SONY VAIO VGN-CS21GN
Aug 17, 2009 | Intel PRO/Wireless 3945ABG Network...
VAIO laptop VGN-FE865E drivers for XP Windows
Cannot find VAIO laptop VGN-FE865E drivers for XP Windows
Jan 02, 2009 | Computers & Internet
Microsoft Windows XP Professional SP2 Logo
278 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
