Question about Panasonic Lumix DMC-TZ1 Digital Camera
I have a note on my camera screen "PLEASE TURN CAMERA OFF AND THEN ON AGAIN" and it apears all the time...
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
Nikon d5000 control buttons not functioning. Reset button pressed & reset clock display appears but cannot use any controls.If I reset again with camera on, I get back to display of photo but cannot...
Just found this on the Nikon support website:-
My D5000 does not seem to respond to controls. Can I reset the camera?
In extremely rare instances, unusual characters may appear in the monitor and the camera may stop functioning. In most cases, this phenomenon is caused by a strong external static charge. Turn the camera off, remove and reinsert the battery, taking care to avoid burns, and turn the camera on again, or if you are using an AC adapter (available separately), disconnect and reconnect the adapter and turn the camera on again.
If the problem persists, turn the camera off, open the memory card slot cover, and using a paper clip, gently press the reset button by the memory card slot. ( NOTE: This will also reset the camera clock. Also note that disconnecting the power source or pressing the reset button may result in loss of any data not recorded to the memory card at the time the problem occurred. Data already recorded to the card will not be affected. In the event of continued malfunction, contact your retailer or Nikon-authorized service representative.
There's more info here:- http://support.nikonusa.com/app/answers/list/p/19
Just type D5000 in the search box
Apr 24, 2011 | Cameras
ZOOM ERROR
Camera malfunction or fault.
Turn the camera on again,taiking care no to touch the lens
Turn the camera off an on again ,if the message still apears ,contact your fujifilm dealer.
Dec 16, 2010 | Fuji FinePix F480 Digital Camera
The camera stops functioning after a few seconds and goes to a dark screen. Pressing the on button again and the wrord "Access" apears on the screen. Please advise.
You need to use lithium batteries which last ages. This is a sign that battery power is low. It happened to my camera and I took it to get fixed. All it needed were more powerful batteries!
Nov 24, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
When I switch camera on it makes a buzzing noise and says on screen 'camara error number E45'
try to remove the memory of your camera and din insert again or try to replace other memory when the error e 45 dosn't apear it main the memory is your problem buy the new memory or try to format all files to your memory
Jul 04, 2009 | Kodak EasyShare V570 Digital Camera
Focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Error
According to sony that error code is refered to as a time and date storage issue.
Follow the steps below to troubleshoot this issue.
NOTE: It is normal for the camera to loose time and date settings when left uncharged for an extended period of time.
  1. Connect the camera AC adapter, and leave the camera in the charging state (powered off) for 12 hours.
  2. Set the time and date in the camera.
  3. Turn off the camera.
  4. Turn on the camera.
  5. Check to see if the date and time have been saved.
Feb 20, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
32 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
