Question about Sabre Televison & Video
I have a Sabre 47" TV model #LCT47PBKA. I've been trying to get HDMI resolution with my PS3. I know how to configure the PS3. The problem is that when I try to use the HDMI function, either 1, 2 or 3 it only give me sound and no visual. My TV manual is no helping at all.
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
leme
  • 25 Answers
SOURCE: PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Posted on Jan 02, 2009
SOURCE: PS3 not working thru HDMI cable
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
addmeps3
  • 61 Answers
SOURCE: PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Posted on Jun 28, 2010
walesarumi
  • 6993 Answers
SOURCE: When I hook my ps3
Turn the system off, then push the power button for 5-10 seconds. That resets the video to the minimum setting.
Or
*WITH NO DISC INSERTED* If there is one, eject it and turn the system off so I can show you from a system start with no disc. This IS using a HDMI cable as well
1)Power on system; do NOT push any buttons on the controller!
2) Over 4 to the left
3)9 down
4) Click 'X' once
5)Click 'X' again
6)Click 'X' again
7)Click 'X' again
That should bring you to some settings list that makes sure that the settings you clicked were what you want.
Good luck.
Posted on Dec 07, 2010
Sabre 47" lcd tv, model Lct47pbka auto-tune finds no channels at all.
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 11, 2016 | Sabre Televison & Video
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
My tv says that i have a resolution mismatch and to change the devices resolution but i don't know how to do that.
I've seen this before when using an HDMI connection to a PS3. You need to hook the PS3 up with Red, White, Yellow cables and then access the PS3's display options. You need to match the resolution sizes for both devices. There should only be a few options in this menu so do some trial and error to find the one that looks best :)
Hope that helps!
Jul 18, 2011 | Emerson LC320EM8 32 in. LCD TV
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do i change my resolution to it's highest amount as i can use hdmi cable for ps3 but not for my pay tv
this probably is ps3 layout config, try to check the ps3 specifications on hdmi output, 1st check for good hdmi cable, normaly cheaper hdmi cables, has low bandwith, so lower resolution on tv.
2nd try on another tv the same ps3, and same cable, then try another cable, check for quality/resolution.
3rd check for flat TV for specifications on HDMI cables, and resolutions supported( Samsung Website)
Nov 22, 2009 | Samsung Televison & Video
I borrowed my firends playstation and used my HDMI cables on it.Whejn I gave it back to him it did not work when he sused his regular av cables.Those same cables did not work on my tv either.The PS3 works...
try your hdmi cables on his tv if you can, if his cables do not work on your tv or his, try
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Aug 18, 2009 | Video Game Consoles & Games
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Televison & Video Logo
293 people viewed this question
Top Sabre Televison & Video Experts
Tom Chichester
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
