Question about Teac USB2 TV TUNER (USB2TVTUNER) Video Capture
I cannot record on my pico life personal note taker
Pico life speaker system & alarm clock for ipod
Press the POWER button so it turns on to either AUX, IPOD or FM and then press and hold SET for about 4 seconds. The time should begin to flash and then you can use the + And - buttons to adjust the time. Hope this helps someone.
Jun 22, 2013 | Audio Players & Recorders
There is incorrect private information when I google my name. it is regarding my political preference
Google only shows information they get from other websites. You might need to contact the owner or administrator of the website containing your information. Click the site you are seeing in google, then look for the contact information page on the site.
Oct 28, 2010 | Computers & Internet
I want to record music from my laptop to my sony mini disc recorder and i dont know how to
using a mini plug for both laptop / mini player...plug into headphones on laptop and into line in mini......when ready press play on laptop while also pressing record on mini........note have your play list ready for continuous recording...(you can always edit later)
Oct 07, 2009 | Sony Net MD Walkman MZ-N510 MiniDisc...
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Yellow/gold wrench is illuminated on dash board
Please note:
Honda makes reference to proper vehicle maintenance in their service/user manual. Consult your authorized Honda dealer before doing anything that may void your vehicle warranty.
https://techinfo.honda.com/rjanisis/pubs/om/AC0606/AC0606O00192A.pdf
Owner's Manual page 193-197.
Resetting the Engine Oil Life
Indicator
Your dealer will reset the display
after completing the required
maintenance service. You will see
‘‘OIL LIFE 100 %’’ on the odometer/
trip meter display the next time you
turn the ignition switch to the ON
(II) position.
If maintenance service is done by
someone other than your dealer,
reset the maintenance minder as
follows:
1. Turn the ignition switch to the ON
(II) position.
2. Press the Select/Reset knob until
the engine oil life indicator is
displayed.
3. Press the Select/Reset knob for
more than 10 seconds. The engine
oil life indicator and the
maintenance item code(s) will
blink.
4. Press the Select/Reset knob for
more than 5 seconds. The
maintenance items code(s) will
disappear, and the engine oil life
will reset to ‘‘100.’’
Important Maintenance
Precautions
If you have the required service
done but do not reset the display, or
reset the display without doing the
service, the system will not show the
proper maintenance intervals. This
can lead to seriousmechanical
problems because you will no longer
have an accurate record of when
maintenance is needed.
Your authorized Honda dealer
knows your vehicle best and can
provide competent, efficient service.
However, service at a dealer is not
mandatory to keep your warranties
in effect. Maintenance may be done
by any qualified service facility or
person who is skilled in this type of
automotive service. Make sure to
have the service facility or person
reset the display as previously
described. Keep all receipts as proof
of completion, and have the person
who does the work fill out the
maintenance record. Check your
warranty booklet for more
information.
Information obtained from:
https://techinfo.honda.com/rjanisis/RJAAI001_OMANUAL.ASP?YEAR=2006
If the information provided to you was useful, please rate my response.
Thanks,
OpenSource13
Apr 19, 2009 | 2006 Honda Accord
Pico/ Resistors what are these??
Pico means small and these look like little small resistors, but don't have stripes like resistors, just part numbers. They should measure as a dead short and be in the immediate vicinity of the STK's
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Teac USB2 TV TUNER (USB2TVTUNER) Video Capture Logo
73 people viewed this question
Top Teac Televison & Video Experts
JOHN TOPLISS
Alun Cox
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
