Question about XFX NVIDIA GeForce FX5200 Graphic Card
Is that graphic card or video card is one - XFX NVIDIA GeForce FX5200 Graphic Card
What is a card video out
not sure if this link will help you out.
A video card (also called a display card, graphics card, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display (such as a computer monitor).
Video card - Wikipedia
https://en.wikipedia.org/wiki/Video_card What is card video out Google Search
Dec 21, 2016 | Computers & Internet
What is visual graphic acdactor ,and the freze
A video card (also called a video adapter, display card, graphics card, graphics board, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display. Most video cards offer various functions such as accelerated rendering of 3D scenes and 2D graphics, MPEG-2/MPEG-4 decoding, TV output, or the ability to connect multiple monitors (multi-monitor).
Video hardware can be integrated into the motherboard or (as with more recent designs) the CPU, but all modern motherboards (and some from the 1990s) provide expansion ports to which a video card can be attached. In this configuration it is sometimes referred to as a video controller or graphics controller. Modern low-end to mid-range motherboards often include a graphics chipset manufactured by the developer of the northbridge (e.g. an AMD chipset with Radeon graphics or an Intel chipset with Intel graphics) on the motherboard. This graphics chip usually has a small quantity of embedded memory and takes some of the system's main RAM, reducing the total RAM available. This is usually called integrated graphics or on-board graphics, and is usually low in performance and undesirable for those wishing to run 3D applications. A dedicated graphics card on the other hand has its own Random Access Memory or RAM and Processor specifically for processing video images, and thus offloads this work from the CPU and system RAM. Almost all of these motherboards allow the disabling of the integrated graphics chip in BIOS, and have an AGP, PCI, or PCI Express slot for adding a higher-performance graphics card in place of the integrated graphics.
Aug 31, 2012 | Computers & Internet
Radeon 7000 series
you can connect your video card to your tv by either a dvi to hdmi cable or s-video. There is no need for 2 graphic cards unless you want to connect more then 2 monitors.
Feb 23, 2012 | Nvidia GeForce FX 5200 Video Card Graphic
I have an Emachine with Integrated NVIDIA GeForce 6100 (graphics up to 128 MB of shared video memory)Video card, was wondering what video card should i get to upgrade for either a s-video out or HDMI to...
You can purchase a new graphics card and install no problem. Dont use S-Video tho, as the quality is not good. HDMI graphics cards are much cheaper these days.
Stay with Nvidia, as the onboard chip for your PC would support this better.
Feb 16, 2010 | Computers & Internet
The Monitor Does Not Open Using My New Video Card
That is clear indication that you have a bad graphics card. Try to look for a pencil eraser and use it to clean the gold pins on your graphics card. I hope this helps. If your card still doesn't work, its probably defective.
May 17, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
Graphic card
A graphic card or graphic adapter is always present on all computer.
When the computer does not have an external graphic card, the video adapter is integrated on motherboard.
By studing multimedia you may need to use software like macromedia director, or 3D modelling software that use a lot of video ram.
If your computer has an internal video adapter with at least 64MB of video RAM, then you can try using the current video adapter, if it is less, then better buying an AGP graphic card.
Here is some choice.
Feb 17, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Graphics Card Problem
im sure that is AGP, because we have the same video card on my other computer. your PCI slot is for sound cards, link modem, etc.. whenever your playing games make sure that you put the video option in to medium or low because that starts the heat of your video card when you use it into the limit. Try to cool the video card if its happening the heat again by using a fan and aim it to the video cards.
Others are overclocking their video cards to push the capability of the video card over the limit. their using a cooling fan or a tube like to maintain the temperature of their video cards. hope that helps
CHARCOIS
Jul 26, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Computer and video card memory/ram
Hello there.
Answers to questions are reported on the website.
Graphics card memory is independent of main system memory. Your graphics card has 256MB of memory dedicated to graphical tasks, such as playing videos, games and animations. Main system memory is seperate and is used for loading programs and applications.
New graphics cards will have even more memory, so to answer your question: no video memory on the graphics card does not have to match main system memory in the computer.
Possible times when main system ram is used by the graphics card is when the graphics hardware is integrated into the motherboard. Please click here to find out more about graphics video memory.
Hope this helps.
Apr 12, 2008 | Computers & Internet
GRAPHIC CARD PROBLEM
Do you have access to another video card to try in there?. It is possible that you have a bad memory chip on that video card.
Oct 12, 2007 | ATI RADEON 9200, (128 MB) AGP Graphic Card
XFX NVIDIA GeForce FX5200 Graphic Card Logo
21 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
