Try changing the bulb,sometimes they short out inside
The switch housing right bar side has moved away from the master cylnder loosen master cylnd bolts and apply lever a little move the two togther and tigthen the bolts you loosened
Check wiring on under side of bike the wires were touching each other making circuit hot all the time
Check thefront brake resevoir make sure it did not come apart from brake lever
Get a test light and start following the wire back. you will find one of the switches or a short is the culprit. I like the check the switches suggestion but a test light will help you to determine if the switch is indeed closed. just clip to a ground and touch the probe to the side of the switch that goes to the brake light. the other side is always hot when the ignition is on
Check the brake light switch at the front level (right hand switch housing) or rear brake cylinder. One or both may be stuck. You may need to clean or replace.
~ Jeff
