I resolved the C:32:01 system error I had on my DSC-H20 when trying to shoot video, by using the camera's memory format option :
-turn camera on
-press menu button
-scroll to toolbox icon
-press center button on wheel
-scroll to "memory stick" tool menu
-highlight "Format"
-turn camera off and back on
"C:32:01 System Error" means, there's something wrong with the memory. Attach it to your computer and format the the card as 'FAT'. Formatting as 'FAT32' or 'NTFS' will produce this error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Describe your Sony Cyber-shot DSC-T50 Digital
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/E.62.10_on_DSC-T9
Have a look at this website above, this is a VERY common problem, with some Fix's
SOURCE: Sony Cyber-shot DSC-T700 system error message
C:32:01 is a "disk format error". It means that your memory card is most likely corrupted.
First, remove the memory card and visually check that the electrical contacts are bright, clean and not greasy. Do not touch the contacts with your bare skin, use a cotton bud moistened with alcohol or methylated spirits if they need cleaning. At the same time, check that the lock switch on the MemoryStick is fully unlocked. Slide it fully to locked and then fully back to unlocked.
If the contacts and lock switch are fine then you can try reformatting the MemoryStick using the "Format" command in the camera menu, do NOT do this on a pc/Mac or in an external card reader. If there is an option to "Full Format" or "Quick Format" choose the full option. Note that any stored images will be deleted, but if you have suitable data recovery software they can still be recovered afterwards as long as no new pictures are taken which overwrite the data.
If that fails then try another MemoryStick in your camera. If the fault remains then the camera is faulty and must either be sent to a Sony Service Centre or replaced. Your camera may still be under the manufacturer's warranty, if so repairs will be free.
I hope that I have been of some assistance; please take a moment to rate my answer.
Testimonial: "Excellent, precise, accurate advice, which solved the problem. Gratitude and admiration "
