Question about Electrolux Microwave Ovens
My Electrolux EMM2017X Microwave does not heat up food. The turntable, light and grill still works. This is the second time that the Microwave has failed this way.
SOURCE: GE Spacemaker XL1800
check conrol circuit, and magnetron, and highvoltage section,
Posted on Nov 04, 2007
  • 3 Answers
SOURCE: Microwave not heating food
check the protector connected at the capacitor and at the magnetron coil windings, check using an ohm meter.,meter should read to zero
Posted on Dec 21, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: MIcrowave light and turntable are working, but food comes out cold
I suspect the magnetron or high voltage transformer, and either part's cost or labor would probably be about the same as the cost of a new comparable unit.
Posted on Aug 18, 2008
SOURCE: my sanyo microwave grill combo ,microwave wont heat food
I have a Emerson combo. It wont heat
Posted on Mar 12, 2009
ginko
  • 19396 Answers
SOURCE: Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
Electrolux combi integral microwave EMS26414W does not microwave/defrost.The display/turntable/light/grill does work
Failure should be found in the high voltage section of microwave oven.
Magnetron, HV capacitor, HV diode or HV fuse, tranformer HV secondary coil
Dado
May 27, 2014 | Electrolux Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Jun 10, 2009 | Microwave Ovens
Microwave oven does not warm food up
I have not solved my problem,I have decided to buy a new microwave rather than pay for this amount of money on a telephone advice when you have said on your site that it is free.I will also spend further amount of money, to call an electrician after your advice,so I will be better of buying a new one.
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
316 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
