Question about KEF Audio KIT100 System
Kef 100 My kef 100 dvd/receiver keeps turning off. Sometimes I can get it to come back on but it keeps turning off after a while again.
  • 1 more comment
  • mattallen Sep 12, 2008
    My system shuts off or freezes after a few minutes of play. I have to power off at the toggle switch and power on a few times to get it to start again. Sometimes it freezes during the "instant theatre" message.
  • fietspomp Sep 27, 2008
    I Have the some problem. After a few minutes the system freezes, turning the back switch on and off will unfreeeze the system.
  • riteshdass Jan 13, 2009
    I have got exactly the same problem. Anyone's been able to find a fix for this?
  • 39 Answers
Send me your email address and I will send you some files which include firm ware upgrade which might fix this.
axel_g@mail.com
Posted on Aug 10, 2008
I have been able to greatly reduce the frequency with which this happens on my system by inserting a powerfilter/surgeprotector between the wall outlet and my KEF KIT100. It may help you too.
Posted on Nov 04, 2008
KEF KIT 100 DVD not opening. Display says "Open"...nothing happens. Plays the movie currently in the drive. Help...
Did you get the software update to work? I must be doing something wrong..
when I burn the files to a cd-r it says error 4 after the question yes/nowhen i burn them as ISO it says bad disc
Can't get it to work.. too bad, since the system has great sound!
Dec 28, 2010 | KEF Audio KIT100 System
My KEF (PSW 2150) ruffer speaker buzzes even with no input connection?
Your amplifier is bad. I sent mine to KEF in NY and they fixed it for $100 US.
Dec 08, 2010 | KEF Audio PSW 2150 Speaker
KEF Audio KIT100 System - I have similar buzzing/clicking.
if you have still the problem, I got the solution from Kef USA. It is somewhat involved in taking the unit apart and replacing a resistor and capacitor. With the instructions supplied any electronic technician or TV repair man can do it in less then 1 hour. email me and I forward the instruction in PDF: Xxel_g@mail.coX . Replace the first X with a and last X with m in my email address.
Jun 21, 2010 | KEF Audio KIT100 System
Kef kit 100 dvd and sub is not working
Hi if you are interested I need spare parts for my kit 100psw contact me if you would like to sell. Aaron@hometheaterpros.net
Jun 13, 2010 | KEF Audio KIT100 System
Yamaha rx-v800 turns off
Sounds like your receiver has a cold solder joint on the power board at a transistor or capacitor. Not a major repair, however, it will probably run $100 or so to pull it apart, hunt it down and fix the problem. Not sure of your problem with the DVDR. Do you have a "line conditioning, surge protection" unit? Not a Power strip or low end monster surge. Panamax, APC, Furman, make line conditioning surge units that keep your power steady and will shut down in case of voltage fluctuation in both directions. They cost from 200 to 2000 depending on the equipment you are protecting. It is a necessary component to any system. Hope this helps.
Sep 27, 2009 | Yamaha RX-V800 Receiver
Scratching and static noise when turned on
Verry common problem with these systems. It is one of the two audio output IC's for the sub. It is best tho to replace them both. Not easy to get to tho. But not
costly for replacements. On the power board there is 4 IC's on one side and 3 1small and 2the same as the other's. Those 2,are the output IC's for the Sub.
The part number for then is TDA7293. The cost about
$6-10 each. Can find on ebay.REPLACE BOTH!!! They sell a kit of 6 for around $25.Sometimes I replace all 6.
Jun 07, 2009 | KEF Audio KIT100 System
Cliking / buzzing noise
there is a known problem with the amp board going bad. contact kef america and they should do repair under manufacurer extended warranty. if not the flat rate repair is around 250. if you compain enough they should do fix for free. hope that helps.
Jun 05, 2009 | KEF Audio KIT100 System
Kef instant theatre - kit200
Nice player. I'm not lucky enough to own one myself, but I found this info which might be worth a try:
Kef Kit 100 & Kef Kit 200 Instant DVD Theatre handset hacks 1. Press & hold the "Skip Back" button, "Play" button & "Volume Up" button on the main unit.
2. After a few seconds the front display should display "PAL RESET"
3. Release the "keys.
4. Power off your unit at the mains.
5. After 20 seconds, power on your DVD player, thats it!
Oct 27, 2008 | KEF Audio KIT100 System
KEF Audio KIT100 System Logo
296 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
