Question about Canon EOS 450D Digital Camera
Err05 - Canon EOS 450D Digital Camera
  • 94 Answers
Is top cover fault you have to open camera and and clean top cover part which is poping up flash. if work then good other wise you have to replace top cover
Posted on Aug 08, 2010
Factory reset
You're in the wrong section. Remove any and all batteries and start from scratch and reset day date time etc.
Oct 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Flash wont pop up err05
Usual cause is either spillage or impact to the flash unit. Most spillage is on the two flash pivots. Pull on top cover when it is attempting to go up to free it and remove the screws underneath and pry off the flash cover. You can now reach the pivot screw (many times rusted - remove, scrape off rust, and put on grease and re-install). BE VERY CAREFUL. THERE IS 300 VOLTS ACROSS THE FLASH TUBE AND YOU CAN GET A NASTY SHOCK!!!!
Oct 02, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Autofocus
Your camera is telling you that you need to phone or e-mail Nikon USA's Customer Support Department for instruction as to how to proceed. There phone number is 1-800-NIKON-US (1-800-645-6687)9AM-8PM EST, Monday to Friday. Based on my experience, they will suggest that you send your camera in for service.
Apr 30, 2013 | Nikon DSLR D90 Digital Camera
My flash wont pop up on my canon rebel xs. says err05 PLEASE HELP
canon rebel xs faces late display on lcd taking 8 minutes especially in cold weather solution please
Nov 20, 2011 | Canon EOS Rebel XS / EOS 1000D Digital...
I have origional Canon digital rebel, any time i popup flash i get err05
Take a look at it from the front and see if the flash will pop up all the way ..usually, (on other models too) this error appears when the flash is not fully popped out ..and something is on the way ..
Either manually see if you can get it out ..or ..look careful cause when the flash is out ..in the right hand side when you face it ..there is a small prong that it is not supposed to be in contact with it ..and it is actually a switch informing the flash out position ..if the flash is not all the way out ..this is slightly touching it ..and i need to be released ..
Jan 12, 2011 | Canon Digital Rebel XT / EOS 350D Body...
FLASH WILL NOT OPEN - ERROR CODE SHOWS, ASKS TO SWITCH CAMERA OFF THEN ON - BATTERY REMOVED AND PUT BACK CODE ERR 05
Top cover giving err05
you can open manualy and clean throughly and front cover edge just push it out side make little space beetween top cover flash and front cover.
try out if work then good other wise you have open camera and clean top cover part which is poping up flash.
Jul 31, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS 450D  Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
