Dear Mr/Ms, I think my ecosave washing machine has some mis-functions. Whenver what process has been done, symptoms are the same. The symptoms are the followings . . . . - blinking error LED light: wash and spin (from the process functions) - error beep (like that Tick Tack, . . .{non-stop}) Please help me something! Thanks What happen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
The error came from an electronic control, the damage usually occurs in the data memory. under normal circumstances should have after finishing washing or spin process, washing machine will turn off automatically, indicated by the beep sound and flashing lights first. if you quite understand you just need to fix the electronic control block only, reset IC memory or the easiest way is to unplug all cables (socket) connected to electronic control, turn on the washing machine and then power off and reattach all the cables socket into place. particularly note the socket cable of  water level sensors and unbalance switches. electronic control block is usually coated with rubber glue. but I often fix it without having to replace the whole (one block / set electronic controls). good luck
Posted on Aug 07, 2010
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Lg fuzzylogic ecosave beeping not wahing
Call a service and they maybe can fix it by phone.It have a sensor for servicing only.You just have to put your phone close to it and they will get info about problem.
Jul 04, 2014 | Washing Machines
I have a Bernette 334d that I replaced a broken horizontal shaft gear. Everything is turning but I cannot get it to make a chain. Think the timing is off. HELP!!!
Hi
If the timing is out, to be honest, you need to get it done by someone who is experienced. It is not a simple job - there are many steps in the process and it must be done very accurately in order for it to function correctly. Timing a sewing machine is childs play in comparison.
Cheers
Oct 18, 2013 | Bernina Bernette 75
My lg fuzzy logic ecosave wf56607 requires a replacement of its drum driver component as it is not functioning properly .while spinnin the whole machine shakes heavelly and stops. pl.could uou...
I'm sorry but, in my opinion, I do not think there is a 'driver' for the drum; the drum speed control is either powering the drum up to speed or it's not. Also I do not think anyone on the forum would be able to supply 'a new driver' if there was such a thing however I could be wrong!!!
I would concentrate on ensuring the washer is level/balance and that there is not something broken inside->
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly.
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Bush A126Q White and the ''end of programme'' light is staying on
Sorry Jo, I think I may have mis-understood your explanation - is there actually a problem with the machine functioning properly or is it simply that the end of cycle light will not turn off?
If it is the latter then simply turn the dial back to 0 before opening the door from the previous wash, this action tells the washing machine to reset itself as the drum is about to be emptied.
I have the exact machine however as it is graded, it didn't come with any manuals, at the end of the wash I just figured thta this was what I needed to do.
Its almost as if you need to double-declutch the washing machine - return the macine to 0 before selecting another cycle.
Feb 03, 2010 | Washing Machines
My kenmore washing machine dosnt cycle from one function to the next can anyone help
With the limited information, my initial leaning is toward the timer being bad, not advancing through the cycles. The timer is where practically every function is controlled on a washer. I can't think of any other item that would give the same symptom
Oct 29, 2009 | Kenmore Washing Machines
Brews coffee at twice the time beeps done when still brewing
Time to run a mixture of white vinegar and cold water (about 1 to 6 ratio) through. Use a clean filter for this. When done, turn off power and let cool down, then return the mixture to the water chamber and run it again. Do this one more time, then pour out the wash and let the unit cool down. Pour in fresh cold water and run through. Do it again--you should by now be getting the rapid brewing (no coffee yet) that you had before. After the second rinse, make the coffee with a fresh filter. Note all the scale in the previous filter that has come through in the cleaning process.
Aug 25, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
SAMSUNG B1215J WASHING MASHINE (front loader )
Hi
i don't think the problem has something to do with the 6 months delay in using it, right now i think there might be 2 possibilities
1. now that you have just started using it,there might be a mistake in the procedure you follow, because washing machines have options of single ring or double ring, you might be taking out the cloths before the completion of the process, so go through the manual to figure it out.
2. Or if there is no mistake in the procedure, then there must be a problem in the programing of the machine. It might have been mis-programed to fill in water after the whole process, if that is the case take it to the dealer to get it right.
Feb 06, 2008 | Washing Machines
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
