Question about Quinny Buzz Three Wheel Stroller
The lever to collapse/fold the Quinny Buzz has come off - is it possible to get a replacement part? The frame is very stiff and awkward to put down without it.
    Champion:
  • Quinny Expert
  • 223 Answers
Hi you need to replace the whole handle which you can get from Dorel uk or ebay
Posted on Aug 07, 2010
Hello, I recently bought a quinny buzz 3 (second hand) and its very difficult to collapse the frame, but it's easy to open it back up. What would I need to do to fix the problem?
Good Evening
It sounds as though you're not quite depressing the fold buttons fully when trying to collapse it, so you're pushing against the natural spring of the chassis which is making it difficult.
The Buzz is easiest to fold when you're standing in front of it. Either remove the seat unit, or make sure it is forward facing and in the upright position before you start. Swivel the front wheel straight and lock it into position. Standing in front of the Buzz, push the left side button in until you can't make it go any further, then roll the right button toward you as far as possible. It should only require a small amount of pressure to fold the unit, but remember, due to the style of the automatic unfold you are working against it to fold it up. If you hear any clicks, pops or creaks, don't force it as you'll break the fold knuckles.
If this still doesn't work, give the chassis a good, thorough clean to make sure no dirt or debris is causing the problem. Use a dry Teflon spray (found in the laundry aisle of most supermarkets) or normal furnature polish with a soft dry cloth and give the whole chassis a thorough cleaning. Then as you're folding it down, follow the black plastic down the central tube as it goes toward the front wheel unit to make sure its totally clean. This should make it smoother to fold.
Failing that, the product will need to be returned to the engineers for inspection - which country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
Help to fold down buggy
Hi, apply the brake.
Go round to front of buggy.
Hold the 2 large grey buttons on side of frame.
1 pushes down 1 pushes forwards do this & pull buggy down towards you, this will fold it as long as the brake is on.
Jul 22, 2010 | Quinny Buzz Three Wheel Stroller
Quinny Buzz seems to be locked up and will not fold. The screw on the long part of the chassis is loose
i have a similar problem i cant get it to shut back down extremely stiff does anyone know how to fix it ?
Jun 22, 2010 | Quinny Buzz Three Wheel Stroller
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
Problem in folding quinny buzz to stiff
I would suggest that when folding the Buzz, stand in front of it first. Push down one of the grey buttons, then slide and push the other, then you can use your whole body weight to push the pram to the floor enabling you to collapse it. It is also easier if you remove the seat prior to folding.
I hope this helps.
Jul 08, 2009 | Baby Gear
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
My quinny is very stiff to fold down could this be a problem with the hydraulics one of the buttons was broken and got a replacement but not sure if its in ok Help
Hello I have the same prob be very careful not to push it my hubby did and has now broken the metal pin that hold the hydraulics in place , so i am now buying a new frame ! E bay !
Feb 20, 2009 | Quinny Buzz Jogger
Quinny buzz hard to fold down
Hi call Dorel they should either fix it or replace it.
Dec 29, 2008 | Quinny Buzz Jogger
How do fold the quinny buzz?
The are 2 grey clips either side...slide the left one forward at the same time as pushing down on the right & then frame will fold down.
Jul 09, 2008 | Quinny Buzz Jogger
Quinny Buzz Three Wheel Stroller Logo
216 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
