Question about Graco Ultra Deluxe 5-in-1 4605 Crib
Graco pack and play sport
I am having a problem getting the sides to lock into place. I have tried to pull up and straight as hard as I can, but, they still wont lock in place. My husband got one side to lock. Is there a trick todoing this?
I saw the solution on the Graco site. I was putting the bottom of the Pack and Play down first, I found out you need the do the sides firstl
Posted on Apr 28, 2008
    New Friend:
OMG I came home today to my Husband sheepishly stating he broke our pack and play for the Grandchildren. He could not lock the one side in place said he snapped it somehow. I found this solution on the web and he was all set to and buy a replacement. So simple and fixed on the spot. God I love the internet. THANK YOU SO SO MUCH!!!
Posted on Apr 25, 2013
I had the same problem. finally i put my foot on the bottom, and instead of yanking hard, i pulled hard continiously with firm pressure until i heard a click. honestly, I am a big man, 6'2" 240, and I had to pull very hard to do this.
Posted on Apr 29, 2008
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
We were able to disassemble our graco playpen but can hardly assemble it again. somthing to do with the locks at the sides. pls advice. thanks
the locks pull underneath and unblock from each sied of the sides but first turn and pull the center of it if you can't unblock them.
it's treaky and coming back blocked very fast. you have handle all of them at the same time.
Good luck.
Oct 06, 2009 | Graco Pack 'n Play
DIRECTIONS FOR GRACO PACK 'N' PLAY
pull and turn the center of it then try to open the side lock. they have to be horisontal from both side of each
Good luck
Sep 09, 2009 | Graco Pack 'n Play
Graco play n pak assembly
turn and pull the center of it then pull up and squeeze the sides to make them straight and try to push down.
good luck
if you need more info let me know
Sep 04, 2009 | Graco Pack 'n Play
Cant get the sides to lock in place
try to turn and pull the center first then ask some help to pull and squeeze the sides. make them straight.
Good luck
Aug 26, 2009 | Graco Pack 'n Play
How do I close up the pack-and-play?
turn and pull up the center. then squeeze pulling up the locks and unlock from each side of each lock. unblock(with help like I had it:D) and pull up the center and the rest.
Good luck.
Pls let me know if I helped
Jul 31, 2009 | Graco Pack 'n Play
Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
May 26, 2009 | Graco Pack 'n Play
Pakc & play set up
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Jan 13, 2008 | Graco Quattro Tour Kentshire Stroller
Graco Ultra Deluxe 5-in-1 4605 Crib Logo
442 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
