Question about Nokia 5220 XpressMusic Cellular Phone
Fail to start up. - Nokia 5220 XpressMusic Cellular Phone
  • 677 Answers
When a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
ou can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Posted on Aug 07, 2010
Val'si 7500 generator keeps tripping and shuts down
Hello dear, have you solved your problem? I am glad to help you out. We know that some malfunctions may occur that will cause the generator fail to start after using a diesel generator for a long time. What can you do when it happens?
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
Hope you can get help from this article: Why Diesel Generator Fail to Start
Sep 21, 2017 | Electrical Supplies
The start button does nothing
Start buttons seldom fail, but door switches fail often.
Have someone good at this open the lid and bypass the door switch, it should start fine.
Door switches can be bought at Amazon or "Sears Parts Direct" or e-bay.
God bless your efforts.
Mar 10, 2016 | Roper REX4634KQ Electric Dryer
How do you "run the software calibration"?
  1. Turn unit on
  2. Pull out the safety key
  3. While holding down the 'start' and 'speed increase' button insert the safety key. Unis should now say calibration.
  4. Press enter on all options until screen does not change when you press.
  5. Press 'Start' (Unit will run auto calibration). If passed, the unit will reset itself. If fail it will say 'fail'.
  6. If you do not see 'fail' power off, then on again once done.
  7. You're good to go. (If unit says 'fail' contact service)
Techmotion Corp does service and repair in many north-east states. Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jun 23, 2015 | RTO Sole F80 Treadmill
Whirlpool WTW4910XQ0 locks and then unlocks when I try to start the machine
Controls rarely fail lid locl could be out of alignment or about to fail the fact you got 2 loads leans towards a lock assembly going bad they fail frequently
Feb 11, 2015 | Whirlpool Washing Machines
Engine start to faill as soon get warm
have your distributor tested - might be getting hot and fail. Just like an external coil.
Mar 23, 2014 | 1996 Nissan Quest
Fail to start
sounds like crankshaft/camshaft sensor is bad or unplugged
Mar 04, 2014 | 1995 Toyota Pickup
How to reset FAIL TO START(over crank)?
Over crank is just that too much cranking with a filed to start. Plese check gas pressure and for voltage on the fuel shut off solenoid
Aug 16, 2012 | Kohler 12 kW Emergency Power System -...
Car won't start when the outside temp is below 20F
the crank sensor can fail at different temps some fail hot some fail cold i would start there
Jul 17, 2012 | 2000 Acura TL
Flash test Fail! wChipID = 0x80 - Disimage Info length = 3600000 checksum = 4d8323a7 -starting counting ...................... ................... checksum = 4ad32f1b Test Fail! Press any...
- Disimage Info
length = 3600000
checksum = 4d8323a7
-starting counting
checksum = 4ad32f1b
Test Fail!
Press any key to continue...
Do not work FM,TV,Camera after using wrong rom
Help please with gsmart i120
Merlinwarwar@gmail.com
Feb 16, 2010 | Gigabyte g-Smart Smartphone
Nokia 5220 XpressMusic Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
