Question about AOC 193FW LCD Monitor
I have been using AOC monitor, model 172S for the past three years. Of late the OSD window appears and does not go off. Please suggest me a solution.
  • sntshbhtngr Aug 07, 2010
    Please let me correct you- My monitor is 172S and not 193FW. If it is a loose contact or short circuit, the values in the OSD menu window would not fluctuate and would remain stable. Three months back, the monitor would become very bright with brightness as 100% but after repeated adjustments and opting out Auto config the values do not change but the window appears on and off and remains for long periods, which is very disturbing.
  • sntshbhtngr Aug 08, 2010
    I had tried switching off the monitor and restarting it after keeping the auto button pressed as written in the user manual but this also did not work. I ahve made yet another observation that this problem is more frequent in rainy season or humid weather. I would like to check if there is any accumulation of dust over some components but do not know how to dismantle the unit as it is press fit. Can someone please guide me how to open up the monitor without damaging the plastic body?
  • 1,555 Answers
It seems that recently your city got a lot of rainfall and a lot of moisture in the air. Who asked you to open your monitor. Kindly don't try to open it. This is just the moisture issue and can be settled down easily. In my organisation recently I've got such 25 units for repair and most of them were ok after I hot blow on the menu keys. few did not got ok till i took a common pin and inserted in the menu button at 5 o clock. You can try it and let me know if its ok or not. I will provide you further assistance as of now 4 more units with same condition are lying with me.
Posted on Aug 08, 2010
    YOUR EAGLE338 WANTED ME TO CHECK FOR DRY SOLDER BUT I HAVE NOT OPENED THE MONITOR AS I DO NOT KNOW HOW TO OPEN A PRESS FIT PLASTIC BODY. THE OSD MENU APPEARS WITH LUMINACE TITLE, THEN BRIGHTNESS AND CONTRAST MENU, ALTERNATING BETWEEN RED AND BLUE AND DISAPPEARS. IF IT IS HUMID DAY, THE MENU STAYS LONGER OTHERWISE IT STAYS FOR 10-20 SECONDS. THE MENU APPEARS AGAIN AFTER 2-5 MINUTE INTERVAL IF IT IS A DRY DAY AND DISPPEARS. THE LOCATION OF THE MENU IS ALSO NOT CERTAIN, MOSTLY IN THE CENTRE OF THE SCREEN OR TOP LEFT CORNER. IF THE LOCATION IS TOP LEFT CORNER, THE MENU STAYS FOR ALMOST 30 MINUTES BEFORE IT AUTOMATICALLY VANISHES.
  • 2,841 Answers
Unplug the power to the monitor and wait 5 minutes. If the OSD is still on then scroll to exit and hit the menu button.
Posted on Aug 07, 2010
  • 4,889 Answers
You mean the OSD menu? That sounds like a loose solder joint. The button when pressed closes the cicruit and performs that particular action. What is happening here is that due to bad solder joint the button is pressing itself and hence you see the OSD menu. I have seen this problem a couple of times before. If you have good soldring skills you can probably handle this yourself.
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
Aug 25, 2012 | AOC LM742 17" LCD Monitor
Osd Lock how to open?
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
Locked osd
May 21, 2009 | AOC 917Sw 19" LCD Monitor
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
AOC 193FW LCD Monitor Logo
113 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
