Question about Fisher and Paykel Washing Machines
Machine not emptying subsequently will not spin what can we do
    Problem Solver:
  • 14 Answers
If you still need to remove the water, setup seperate syphon hose. (Garden hose will do, place the hose in the top of the tub submersed under water, turn garden tap on & when the air is out of the garden hose turn tap off & disconnect the hose, providing tap is lower than the machine the water will drain away through the garden hose.)
Remove the power cord from wall socket, lean machine against the wall at 45Deg angle. If yours is an older machine with the access panel in the front panel access the pump through it...
Disconnect pump.
Put a towel over connectors to stop them getting wet in next step.
The pump is removeable by twisting 1/4 turn anti-clockwise, you need to lightly release the barb clip to allow the pump housing to turn. Hopefully you can now see the debris causing the problem.
Make sure all lugs are engaged when reassembling, if one is not the pump will be hard to turn.
EVEN WITH PRODUCT OFF AT THE DISPLAY PANEL THE DRAIN PUMP IS STILL LIVE, MAKE SURE THE POWER PLUG IS PULLED OUT OF THE WALL SOCKET
Posted on Aug 07, 2010
Will not spin or pump out water except when empty
If your machine is a FAV6800A or FAV9800A see if this post will help.
Clutch Fix
Jun 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Washed a rather heavy rug, on _cotton/Heavy" The machine "beeped" for end of cycle, but the tub didnot drain, nor did it spin. Subsequently, when attempting to run on any other cycle, the tub (with dirty...
Have you checked the filter? if it is blocked the machine will know it has not emptied and will do odd cycles but not work, a google search will reveal the location of the filter, except my new maytag that has none so a turn over and dismantle it the only option, after bailing,
Nov 01, 2009 | GE WPXH214A Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
