Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
I need a service manual or schematics for Behringer MX3242X mixer and Power Supply Unit
4 Suggested Answers
  • 5603 Answers
SOURCE: BEHRINGER PMH1000 POWER MIXER FAULT - TRIPS HOUSE ELECTRICS
THIS MAY BE NORMAL. The starting transients can trip RCD's or GFCI's as we know them due to high frequency components that are not balanced due to capacitive coupling. IF you have the inputs connected to OTHER devices such as effects modules that also have line power to them there may be a ground loop.
ALWAYS connect any interconnected device to the same power source for equipment safety. Behringer is stingy on schematics.
You MIGHT try using a decent line filter to supply the unit. It has been a while since I repaired my 1000, but I don't recall any specific thing in the design to unbalance the current, HOWEVER the power does go through a thermal switch on the heat sink for the power transistors and the wiring CAN be dressed so that it might couple to the other internal wiring AND the safety ground. Suggest you try a small lamp in series with the safety ground (third wire) to see if you get any appreciable current there during startup. Make an adapter... DO NOT cut into your power cable to do this.
Posted on Jul 27, 2009
  • 5603 Answers
SOURCE: behringer pmh mixer manual
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Posted on May 25, 2010
  • 5603 Answers
SOURCE: I need a service manual for a behringer pmh500 powered mixer
If LED's or other indicators are lighting, then the power supply is likely OK.
If nothing lights, then the supply has fried and LIKELY fried as a result of one of the power amps shorting.
Posted on Jun 18, 2010
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
Where can I get a schematic for the output section of the mixer on a behringer 1280s?
No hope. I have replied to this sort of question elsewhere but Behringer are very protective of their stuff and won't even let us have diagrams. Only Behringer service. If anyone has any Behringer service manuals / schematics we would love them
Oct 31, 2013 | Behringer B3031A 2-Way Active Studio...
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Behringer XENYX 1620FX, won't power on. Phantom power works(?)
Here is a schematic close to your unit:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
The phantom power is a separate rectifier and regulator. See page 11 of the download service manual for the power supply. Be careful when working on line operated switching supplies. I suspect you will find one of the other supplies is dead. If the phantom is OK, then the switcher is working and one of the rectifier/filter/regulators is bad. Check if an electrolytic cap is shorted.
Jul 21, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I have recently purchased a Behringer Eurolive 1800 sub, what outs or sends do I use on my mx3242x to the amp
You use the balanced MAIN outputs. They are XLR and you should run those on balanced lines to your AMP which should have EITHER XLR inputs or TRS balanced 1/4 inch jacks to receive them.
DO NOT use mono inputs on your amp... make sure they have balanced inputs.
Note, for SAFETY of your equipment, ALWAYS power any connected stuff from teh same receptacle or power distribution system.
Apr 03, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer MX3242X audio mixer, faulty channels
Hi ****
Behringer are pretty good at supplying schematics and information in PDF form. Have you approached the distributor in your country. They are pretty good at supplying info, and dont usually charge. Just rather see the product sorted out. Email a few and see how you go :)
regards robotek
Jan 25, 2009 | Audio Players & Recorders
Need schematic for behringer mx3242x mixer
Click below for free schematic down load and register there;
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
294 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
