Question about Sony Playstation 3 (PS3) Console
The video and audio will not show up when using the standard jacks but everything works fine when using high def cable what would cause the standard cables not to work.
    Novelist:
  • 105 Answers
Hi, this happens because your console is set to use that definition. When you change tv or cables, just reset the video settings. It's pretty simple: switch on your console, hold on the switch until you hear 2 beeps. Now video settings are reset. Regards, Peter
Posted on Aug 07, 2010
I have sound but no picture
Check your connections between your Roku box and your TV more than likely you have the audio cables plugged into the wrong jacks, Using a single HDMI cable would eliminate this issue if you have an available HDMI input on your TV. Notice which jacks are the audio output jacks on this pic, make sure these are connected to the input on your TV, the ONLY time you don't use these jacks id if you are using the HDMI connection, they are REQUIRED for composite video, component video (high def color) and S-video.
May 25, 2015 | Roku XD Streaming Player 1080P Wireless-N...
Is the harmon kardon avr 225 receiver hi def? we had a "non" hi def tv hooked to our receiver and we are replacing the tv with a hi def LED. do we need a new receiver?
It does not have any of the usual HDMI or component video jacks on the back. The highest 'def' video it supports is S-Video (standard def).
http://en.wikipedia.org/wiki/S-Video
It is NOT necessary to route video through an audio device. Your TV is the ultimate and most logical first recipient of any high def video content.
Whatever video you elect to pass through this thing is not modified in a good way if at all. You COULD just run the HiDef video straight to the TV and not have to worry about what could be happening in the excessive and unnecessary cabling that takes it for a trip through the receiver.
The receiver can still be managed by running its composite (standard def) video from the Monitor Out to a composite input of your new TV.
Likewise, no digital audio would improve from passing it through any device that just acts as a stepping stone to the receiver and ultimately your ears. That iswhy all decent A/V gear has provisions to run the signals separately to their optimum electronic end-user.
Sep 08, 2011 | Harman Kardon AVR 225 Receiver
I am trying to hook up a Panasonic Blu Ray Player to my Toshiba flat screen TV. The red cable which is the audio cable doesn't seem to make the audio come out on the TV. I tried every single slot on...
They print manuals for these things.
Have you looked at them?
The specific products you're inquiring about are not showing in your post. Name the makes AND models first, then we'll look for the manuals. Then (maybe) find a solution. You might find it them the manufacturers' support sites or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
The standard color codes for analog audio are Red/White = Right / Left; Yellow = Composite Video.
Single coaxial or optical SPDIF cable = digital stereo or multichannel audio
Red/Green/Blue = Hi-Def component video
HDMI can carry multichannel digital audio and Hi-Def video from a source to a TV
May 15, 2011 | Toshiba Audio Players & Recorders
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
I want to connect our VCR to the new Sharp HDTV,but I do not find audio,video out on the tv.How do I link the two?
Some HDTVs can output analog video and audio but if you say your HDTV does not, then you would have to use some other tuner/box/decoder/converter such as a cable box if you have cable TV service or a DTV converter box for over-the-air TV or a satellite box. The VCR would connect to the tuner/converter box and record analog video and audio using the RCA yellow video and white audio jacks. Standard VCRs cannot record high-def video except as down-converted analog video.
The VCR would then connect to the HDTVs inputs (yellow, white) for playback.
Mar 03, 2011 | RCA VR651HF VHS VCR
I bought a Nintendo Wii off of a guy and I didn't realize when I did that it came with Hi-Def RCAs. My TV only has a standard RCA hookup. I was told that I could still use the Hi-Def RCAs but what colors...
Those are not High Def RCAs.
The cables you received are called "component" when the picture is broken down to its component colors, red, green, and blue.
When compared to "composite" cables (RCA), the yellow is all the components in one, which is the video cable. The other red and white are audio.
Your component should be RGB, Red & White (audios)
What you need to do is buy a composite cable for the Wii, which shouldn't cost that much--usually under $10 bucks. Save the component cables for when you get a new TV since those are the more expensive of the two!
Feb 08, 2010 | Nintendo Wii Console
I turn on my playstation and it works but i got no picture or sound. Recently i took my playstation to a mates place. my tv is standard def. my mates is high def 1080p. when i connected my sony to my mates...
sometimes ps has this problem as i m also havin a ps2 n ps3 n i play them on my standard definition tv ....i also hav to restart again n again till 10 to 12 times then finally it starts this may be a plate problem go show it to ur nearest service center.......hope it works
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Samsung lcd tv not working as the picture is blurry and not clear
are you watching a high def channel? Standard def channels appear blurry, rather more like youtube videos, because the technology is advanced enough to really show all of the flaws.
May 24, 2008 | Samsung Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
