Question about Kenmore Washing Machines
Motor gets hot, smell like something burning ,plug gets hot
  • 39 Answers
Got a bad motor or gear case. Caution if plug is hot could catch on fire the motor is drawing to many amps designed for the power cord. How old is it ? what kind of shape is it in and how often is it used ? Taking this into consideration your best intrest would probably be to spend the 200.00 - 600.00 that it will cost to repair (unless under warranty) and apply to a new washer with a warranty.
Posted on Aug 07, 2010
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
When the machine goes into the spin cycle the tub barely rotates a hot burning smell slowly appears and when I turn the machine over and inspect it the clutch is extremely hot. Motor and gearcase are cool...
This could be something trapped between the inner and outer tub or even your bearings have collapsed.Get a torch and look inside the drum through the tiny holesnto see if you can see anything if there is something.you will have to remove the tub to pump hose to get at it
Jun 11, 2010 | Washing Machines
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
I have a hoover mach 5 multi-chamber cyclonic vacum cleaner and it keeps getting hot and quitting.it's got a strong smell like something is burned when it gets hot also.
if its giving off that strong smell then the motor is bad. probably caused by not keeping the filters clean. on any bagless machine one has to clean the entire vacuum after almost every use to keep the unit operating correctly
Dec 31, 2009 | Vacuums
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Washing Machines Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
