Question about Nokia N95 Cellular Phone
Hi, i hv nokia n95 8gb. it shows a speaker problem.... dere is 2 speakers for multi media progrms. bt d problem is dat d right side speaker emit sound with sm noise...like ZZZUUZUUUU. so wat can i do....plz hlp me...
  • 677 Answers
when a speaker makes that kind of noise ,it means that the speaker is damaged,and you will need to replace the speaker for clearer sound production.
Take care.
Posted on Aug 07, 2010
Bt-100 bluetooth speaker volume to low can't turn up
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
Jun 30, 2014 | Digix BT-100 Portable Bluetooth Wireless...
My soma bt speaker will no longer pair
On the iphone in bluetooth menu delete all soma speakers.
on the soma put it into bluetooth discovery mode
on the iphone wait till soma speaker shows up
select the soma speaker NOT the arrow on the right side
wait till the iphone reads 'connected'
if you are asked for a passcode use 0000
Mar 19, 2014 | Imation Xtrememac Soma Bluetooth Portable...
I have a nokia 5030c-2.i kept an unlock code for it bt nw itz nt opening...im pretty sure dat i knw d ryt code..bt it stil shows ''code error''..very worried..please give me a solution
Remove the battery and leave it for 15-20 minutes and try again ...coz sometimes..due to continious irritation cause the program/function mislead.Good luck
Jul 22, 2011 | Nokia XpressRadio 5030 Cell Phone
The two speakers emit no sound, they are not found under devices, but you hear a bit of static when you plug them into the port. Surely there cannot be drivers for such a device.I have an Acer with...
Hi maggiepiano1
Check first if you plugged the jack in the right slot ( green ) .
Your speakers don' t need drivers but your sound card well . Check that also .
Best regards ,
fanaudi .
Jul 04, 2011 | Insignia 2.0 Speaker System (2-Piece)
How i can set auto key pad lock
go to settings then phone settings then automatic key lock adjust the time
Apr 27, 2011 | Nokia N72 Cellular Phone
I hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any...
i hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any solution so dat i may nt loss my data and free. inf me on y email shin_dragon_pke@yahoo.com help is need ASAP
Jul 02, 2010 | Computers & Internet
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Left computer speaker is unpredictable
Take no offense but after 8 years, you got your moneys worth. Unless you're good with the soldering iron and schematics, call it a great investment and update your speaker system. I imagine your computer is newer than the speakers and you can take advantage of some 5.1 surround sound! It's really great if you do any gaming,too.
Since you'll probably be getting rid of them anyway, you might want to crack it open and see if there's any loose wiring that can be fixed.
Thanks for using Fixya.com. Please rate this tip accordingly. I wish there was a better solution but I usually get 5 years out of mine so I feel jealous. :-)
Jan 11, 2009 | Harman Kardon HK695 Computer Speakers
Nokia N95 Cellular Phone Logo
134 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
