Question about 3Com OfficeConnect Wireless Router
How to connect wireless with windows 7 - 3Com OfficeConnect Wireless Router
    Problem Solver:
  • 8 Answers
Start ->Control panel -->Network and Internet-->Network and Sharing Center -->Then click on Connect to a network-->Choose your network then click on connect --> type your password-->thats it
http://www.chasms.com/windows7/nasc.htm
Posted on Aug 07, 2010
I have a 3G dongle (ZTE MF626) and can not get access to the internet. I tried with two Laptops via Wireless. One with XP and the other with Windows 7. The wireless is recocnizing the ESR 6650 but can not...
Try this link
The Connection Manager installed from the USB modem does not include Windows 7 Drivers.The Connection Manager M03 does include Windows 7 drivers.
For Windows 7 support do only one of the following two options:
a) Update your currently installed Connection Manager using the Windows 7 driver tool or...
b) Install the new Connection Manager (M03) after un-installing your current version.
Nov 01, 2010 | Computers & Internet
Is Encore ENHWI-N3 Wireless Router windows 7 compatible?
You should be fine using it with Windows 7, as there is no drivers as such for the router, you are just using the wireless (or wired) connection to the router, and windows doesn't really care how it gets there. As long as the adapter you are using to connect to the wireless network is windows 7 compatible you should be fine.
Hope that helped!
Oct 16, 2010 | Encore ENHWIN3 Wireless Router
Can't find a driver for SMC2802w PCI card for windows 7
There isn't a Windows 7 driver since it's about 5-6 years old now and it's no longer supported.
You'll need to purchase a new wireless card for Windows 7, sorry :(
Sep 26, 2010 | SMC EZ Connect g SMC2802W 802.11g/b...
I tried to access my network by the adapter Linksys WUSB54GC Wireless-G USB on windows 7 but I can't. the driver with adapter for windows xp and vista I installed the vista driver, it's don but not...
You have to connect to your network without using wireless then u have to go to the linksys website and download the windows 7 driver. Install that driver then u can connect with wireless. Worked for me! Gl.
Aug 04, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I have a msi PC60G Wireless card but it doesn't seem to want to connect with my new Windows 7. What can I do?
Windows 7 should download the driver by itself, try to connect the pc to internet trough a wired connection and run windows update, then look in the "optional updates" and select the checkbox of the wireless card item. once downloaded windows shold install it alone. I hope you can make it work!
May 12, 2010 | MSI PC60G (MS-PC60G) Wireless Adapter
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Jan 31, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
How do you connect WIndows Vista to Windows 7 through ADHOC?
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 04, 2009 | Computers & Internet
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
3Com OfficeConnect Wireless Router Logo
59 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
