Question about Acer Aspire One AOA110 Linpus Lins Lite Version Notebook
When are turn on my laptop.. It shows only windows screen with "press f2 to change set up" and "press f12 to change your boot order" at the bottom of the screen. Later, it turns out to a blank screen.
  • 487 Answers
Hi, you haven't said what operating system you have, but here are two options. Restore windows with your windows CD. Or you can boot into safe mode by pressing the Del or ESC key during initial boot, select start in safe mode, from where you can reset your operating system to an earlier time before the problem. Both of these will not loose any saved files.
Posted on Aug 07, 2010
F2,f8,f10,f12 don't work to get bios menu . how can i change my bios setting during set windows up by usb.
if you are trying to get into your BIOS you have to press which ever key when you are booting the system you can't be in windows because it wont get the proper key stroke to enter the BIOS.
Mar 19, 2015 | Computers & Internet
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
The computer is not starting automatically eventhough the power button is switch on. The screen only shows the message" In touch with tomorrow", Theres two choices to press,F2 for Set up menu and...
Remove the Power cord and battery
Hold down the ON button for 30secs (dispersing all internal voltage)
Plug the power cord back in (leave the battery out for the moment)
Turn on
Does it work?
If so, shutdown normally
Re-insert the battery
Turn back on
Mar 16, 2011 | Toshiba Computers & Internet
Hai my name is laman my lenovo laptop just haveasmall problem it's displays only press {f2} for set up press f12 for boot device selection & can not execute so any one please solve this problem
Pressing F2 is the shortcut key to enter in cmos setup or bios settings where you can setup interrupt request and the direct memory access and also changing system date and time. While the F12 key is a shortcut key where you can select a boot device which are the hard disk drive if it's loaded with the operating system like windows xp or windows 7 etc., and if you are going to install or reformat your computer select the cd/dvd room drive to be the boot device. Supposedly the computer will load after the F2 or F12 appears on your screen if you have the functional operating system. But if your computer still restarting and always appearing on your screen the said F2 and F12 keys that means it is required to be reformat your computer. But before that you try to tapping F8 key while turning on your computer and select safe mode and press enter, after loading and still restarting that is the time to format your computer but you must back up your data or files that you saved on your computer. Call a computer technician or IT that know how to back up and can format your computer. Have a nice day.
Mar 14, 2011 | Lenovo Computers & Internet
My HPdv6910 has stopped working. I see the power light and battery light on but the hard-drive light is not on and the screen is blank even after I plugged it for more than an hour
reset boot formate to f12 but first lets get that blank screen off keep pushing f2 f2 f2 f2 thre or four times intell first page starts up then push f2 then use arrow keys on key board and at bottom booting log you shoud be set up on f2 change boot log f12 then pressf10 to save restart computer then when computer starts up push f12 then run windows under d: drive the it will ask you start windows run windows from disc or trouble shoot go to run windows after that you shoud be ok.
Feb 17, 2011 | HP Pavilion Dv6910us Notebook
It is stuck on the " acer empowering people" screen it gives me options at the bottom to press F2 for setup and F12 to change boot order but when i press either of these nothing happens ive tried...
try restarting and push esc a few times should go to boot option screen ,,set it to boot from hdd,,or jus put ur cd that came with or windows disk and repair,,,,,check acer website also
Nov 03, 2010 | Computers & Internet
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system restore..to do system restore try this link..see the use system restore topic
Oct 02, 2010 | Toshiba NB205-N210 Netbook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Computer will not run windows xp anymore?
Hello, do you have a floppy disk or anything in the drive? also check the boot order in the BIOS (F2) and see can your laptop see the hard drive. What is your Laptop, What is your version of Windows/Linux?
Feb 19, 2008 | Computers & Internet
Acer Aspire One AOA110 Linpus Lins Lite Version Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
