Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
My coffee tastes bitter and water is not hot
My coffee tastes bitter and water is not hot enopugh
    Problem Solver:
  • 5 Answers
The problem is that there is old coffee oil sediment in the black parts on the machine door. Every time you make coffee, no matter how well you clean the guts of the machine, this coating remains forever. If your really handy, you need to remove these parts very carefully. Take it apart! Don't drop the spring!!!. I soak these in a good cleaning solution and scrub them. Do a good job. I use little tooth brushes and other stuff. It not a difficult task. But go slowly. I photograph before starting so I know how it all goes back.
This is the only way to get the really burnt taste out. Lots of luck.
Also descale too.
Posted on Aug 20, 2010
    President:
  • 2,030 Answers
You need to delime or descale the unit with white vinegar, that will clean it out
Go here to get the manual and it will tell you how to do it....
http://www.retrevo.com/support/Delonghi-EAM3500-Coffee-Makers-manual/id/3878ci577/t/2/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 07, 2010
Coffee tastes bitter
two days is not enough for the machine to scale or get dirty from old grinds usually would be either coffee or water problem ---but depending on machine you have didnt specify- can be residue from plastic or container try running a vinegar cleanse than 3 just fresh water then try a coffee drop and see it taste is any different if no change bring back for a refund or exchange
Aug 29, 2016 | Coffee Makers & Espresso Machines
How can I avoid bitter coffee?
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
Espresso Machines Coffee Makers Grinders Reviews
Sep 08, 2014 | Coffee Makers & Espresso Machines
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Over time, my coffee has become acrid and bitter. I use fresh ground coffee and clean my pot regularly...what else should I do?
There may be some buildup in the machine other than in the pot itself. To test this, try running the brew cycle with no beans. Taste the hot water. If it's acrid and bitter, your problem lies in buildup (such as the basket). Otherwise, if the hot water just tastes like hot water, then the temperature of the water has probably become too high (that will make coffee tastes more bitter). If this is the problem, there's probably no fix (just make sure you fill the reservoir with cold, not hot, water).
Sep 26, 2013 | Bunn Pour-O-Matic VPR
Why are some coffee's more bitter than others?
There are several factors resulting in a bitterer cup of coffee:
The bean - Robusta beans are more bitter than Arabica
Roasting - darker roasts are generally more bitter
Brewing method - espresso tends to taste more bitter
Feb 07, 2013 | Wine & Spirits
Why is coffee bitter?
Bitterness is a dominant quality in the overall taste of coffee. You need a certain amount of bitterness to balance out the flavor. There are two types of chemicals that give coffee most of its bitter taste - both are antioxidants.
Jan 10, 2013 | Wine & Spirits
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Apr 05, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
BITTER TASTING COFFEE
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
Mar 13, 2010 | Rancilio Coffee Makers & Espresso Machines
My coffee tastes bitter and when I open the maschine and look inside there is coffee resedue everywhere.
Could be that your water is not hot enough. I also recommend using bottled water instead of tap water. The coffee resedue most likely stems from grinding to much. Need to adjust the grinder.
Sep 24, 2009 | Solis Master 5000 Espresso Machine
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Feb 03, 2009 | Saeco Aroma Espresso Machine
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
653 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
