Question about Unicom UTP Network coupler (ILC-S504C-SH)
Wire order in new clip to replace broken end end 10 base T
  • 105 Answers
From left to right:
1. White/Orange stripe
2. Orange/White stripe
3. White/Green stripe
4. Blue/White stripe
5. White/Blue stripe
6. Green/White stripe
7. White/Brown stripe
8. Brown/White stripe
Hope this helps!
Posted on Aug 19, 2010
How do I remove the antenna from my JABRA Crusier in car speaker phone? The antenna also acts as the clip to hold the Cruiser to the visor.
The wire antenna is removeable without breaking it. The ends of the wire that are inserted into the back of the unit are bent (L-shaped) inside the unit. With the back of the unit facing you, gently slide the left end toward the center and lift out. Then slide the right end toward the center and lift out. Reverse procedure to replace wire antenna visor clip.
Jan 10, 2013 | Jabra Cruiser InCar Speakerphone Black
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
Removal of the right side cvshaft on a base 1997 dodge avenger
REmoce the rubber boot. Clean away all the grease from the joint. Rub your fingernail on the 3 tracks which the drive end slides on in the diff. Near the outside you will find a round wire like spring clip push a small screwdriver under it and and take the clip out. The drive end will slide out.
Oct 08, 2009 | 1998 Isuzu Trooper
Clip on wire to connect to oven element broken
It really is not difficult to cut back the bad wire, strip off a little of the insulation at the end and crimp on a new terminal to connect the wire to the element. Go here for Wire & Connectors
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Ovens
'06 Boulevard c50T - how do I replace left frnt turn signal
replace the turn signal which should come with a new wire and replace clear down to the wire connection(should even be a clip connection). don't worry about re-soldering
just order the new signal, wait for it to arrive and see what you're getting into before messin wit it
Sep 20, 2009 | Suzuki Boulevard C50T Motorcycles
Won't spin in agitate, spin or rinse cycles
this sounds like it could be one of two things:
The lid switch doesn't work or the coupling from the motor to the transmission is broken. are you mech. inclined, as this isn't hard to do?
following is a set of steps to disassemble the machine to get to the part:
  1. Using a Phillips screwdriver, remove the screw from each side of the console.
  2. Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top.
  3. Lift the console up and lay it on its back.
  4. Unplug the harness connectorfor the lid switch.
  5. Insert a flat screwdriver into the front edge of the clip (located on both sides), and pry back. Remove both clips from the holes in the cabinet and slide down the other end of the clips and out the slot in the rear panel.
  6. Open and hold the lid while grabbing the cabinet front opening. Be sure when tilting the cabinet that the back edge clears the vacuum break.
  7. Tilt the top of the cabinet toward you by pulling on the lid and opening of the cabinet. This releases the back slots of the cabinet from the tabs in the back of the base.
  8. Carefully pull the cabinet away from the base of the washer and set it aside.
    Now you have access to most of the parts.
If you need to replace the switch, you will see it on the underside of the cabinet. Two screws hold this in place, with a retainer. Remove the screws and replace the unit. assemble in reverse order.
If you need to change the coupling, following are it's instructions
Now you see the pump on the front of the machine. Remove the clips there, and pull the pump straight forward. Same for motor, place a hand firmly under the motor as it will drop out once the clips are removed. On the back side of the motor, you will see three pronged retainer on motor and transmission shaft. When you buy a replacement for this, it will come with new ones if these are broken. Place the rubber onto the three pronged retainer, replace motor onto transmission and reconnect.
Reassemble in reverse order
Hope this helps
Aug 27, 2009 | Kenmore Washing Machines
Won't wash or spin power ok
the motor to transmission coupling is broken. You need to get the cabinet off. Following are instructions for that.
  4. Unplug the harness connector for the lid switch.
Now you see the pump on front, remove just the clips, you don't have to take the hoses off unless they are too much in the way but you can swing that away to get the motor off, same with just the clips. There is a coupling on the back end of the motor. This is probably broken. Go to appliance parts store in your area, for less than $20 you get new one, replace and reassemble in reverse order.
That should fixya!
Joe O
Aug 22, 2009 | Kenmore Washing Machines
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Cooling fan
depends on what the socket cpu your running is you can go bigger with the a bigger heat sink
May 20, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Unicom UTP Network coupler (ILC-S504C-SH) Logo
107 people viewed this question
Top Unicom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Unicom Computer and Internet Expert? Answer questions, earn points and help others
