Question about Dometic Rooftop RV Air Conditioner
When the AC fan shuts off, the compressor appears to be stuck. It continues to make a humming sound as though it is running. If I remove power and return power it hums momentarily and then shuts off. Is it OK to allow it to "hum"? I constantly kill the power when the fan shuts off in fear of harming the motor or compressor.
  • Dometic Master
  • 6,674 Answers
Yes, not good for compressor to stay on after being shut off, and hitting the breaker to stop it is a good idea. Sounds like you have a faulty/sticky relay. Not an expensive part, and shouldn't take any longer than 1/2 hr to change. Have a technician, or electrician look at it and give them a model number of unit so they can make sure they have a relay with them when they come. That way, another trip back, as well as a service charge will be eliminated. You have capacitors in the same area, that are very dangerous to work around if not experienced, so make sure the person is experienced, to avoid shock from 250-370 volts stored in those capacitors.
Posted on Aug 07, 2010
  • vaniec7 Apr 20, 2011
    Mine just started doing this very thing. Humming even if the ac thermostat is in the off position. It only stops when I turn off the 20 amp main. My question is, how long can you leave the main off, while using the 30 amp main to run coffee pot, microwave, etc.?
    Thanks for the above advice..and any that follows..
  • Mike Butler
    Mike Butler Apr 21, 2011
    Your 20A circuit in breaker panel should only be running the AC. It shouldn't affect anything else in the RV, unless someone has added a receptacle or light or something else, but normally from factory, it will be on it's own circuit. By all means, leave it in the off position. Be aware that depending on the year,model, serial number, and thermostat used, the relay for that can be in a control box at ceiling assy.,as well, but relay in some cases is not the problem, but thermostat, wiring etc., will need to be checked as well for proper diagnosis.
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
Central ac compressor keeps running
Sounds like the contactor is stuck. Turn the power off on both units and remove panel on condenser. Pull out on the contactor if engaged. Likely still needs replaced, it's going to happen again.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 25, 2017 | Heating & Cooling
Carrier outside Unit will not power on. Every 45 sec's to a 1min it will make a humming sounds like its trying to power on but wont. The fan unit inside will come on but will not disburse cold air
You probably have a bad run capacitor in your outside unit. You will need to cal a service tech to test and replace it, until then turn your system off until it is repaired. Continuing to try to run it will over heat the compressor and fan motor and cause them damage.
Jun 16, 2011 | Carrier Heating & Cooling
I replaced the fuses with the proper ones thinking that that was why fan on ac unit was not on. I did the 24 hour off on electrical panel, and replaced fuses, now i hear a click then a humming sound coming...
The humm you hear is the compressor. Turn your unit on and let it run for a couple minutes and grab the large pipe at the outdoor unit. If it's cold, your compressor is running. If your fan didn't turn on, there is a good chance your motor is fried. It could be your contactor, but I doubt it. The compressor and fan are wired through the same contactor, so when one comes on, so does the other. DO NOT run your unit for more than a minute or two with the outdoor fan not running. If you continue to run it, it's going to go out on high pressure and turn back on, and so on, and so on, until it fries the compressor.
Sep 28, 2010 | Carrier Heating & Cooling
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Window AC unit
See if your motor is okay 1st. Find your wires feeding your Fan motor. (This means the 2 power wires L1 & L2 if 220v or L1 & N if 115V) Carefully put the power to these 2 wires and see if you hear the motor hum or start. If it hums the run capacitor could be bad.Try spinning the motor with the power applied. If it starts most likely the run capacitor is out. If it starts without you helping it the control board or switch is most likely out.
It is possible the unit has a energy saving setting. If it gets locked into this the fan may not run.
If the unit has electronic controls and an electronic display read out, the board is the most likely suspect. Unplug it and see if it resets.
If not then the board is probably out with a stuck relay or stuck program. New board time. Or replace the unit.
If it has a rotary or push button type control then either of these 2 switches are suspect.
Jul 12, 2008 | Fedders AEQ07FBG Air Conditioner
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
389 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
