Question about LG GW300 Cell Phone
Clicking camra start loading after some time respond "external memory is not available even data card inserted other features like sound, images works
My mobile problam is intarnet use in to iinsufficent memoriy unleble to priced
Posted on Aug 26, 2010
My dopo D 7015 has a problem when i try to downlaod. it starts to down load but never gets any farther than that. A "error when downloading"comes on the screen.why?
You may need more space--try deleting data or apps from the tablet's internal memory. Move what you can to external memory--probably your micro-SD card (if available, and that's possible--given certain apps, that may not prove possible). Always, it's a great idea to take some time to delete data, cache (temporary memory) and apps proving harmful or no longer necessary! Your micro-SD card (or other compatible external storage) generally isn't included with tablets or phones--you may purchase the cards at stores or online.
Dec 16, 2013 | DOPO Tablets & eReaders
I want to copy image from my phone to my computer
Connect the USB cable that came with your cell phone, connect it to the cell phone and then plug the other end of the cable into the USB port on your computer. The computer will see the cell phone as an external storage device, then open the photo folder and copy the photos to your computer.
Feb 04, 2013 | Nokia 6121 Classic Cellular Phone
I currently have samsung camer with over 300 photos on there. Last night i changed the settings so the time and date would appear on any futher pictures taken. However it has seemed to clear my camera and...
You can recover lost photos from memory card of your digital camera with this
1. Do not save any new photos into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Jul 31, 2011 | Samsung L200 Digital Camera
I removed my SD card without turning the power off and now I can't read the card. Can the images be recovered?
Dont worry, a good SD card recovery program can help you. you can recover your images from SD card with asoftech photo recovery program.You can see
http://www.asoftech.com/apr/
It tells the steps how to perform picture recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Mar 26, 2011 | Canon Powershot A1000IS Digital Camera
It says that my "Memory Card is full" even though
1. Make sure you are saving all your images to what is called the "external" memory, not the tiny internal memory.
2. Format your memory card using the format feature on your camera.
Mar 08, 2011 | Panasonic Lumix DMC-FX12 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Shutter speed won't go over 5 frames a sec. on d300
Even if your camera is rated at shooting more than five continuous frames at a time, those are stored in a memory buffer in the camera, when the buffer is full the camera writes the images to your flash memory card. How fast the memory card can accept the data will determine who fast space is made available in the buffer for a sixth or seventh shot.
The main limitation on how many images can be shot in continuous mode is based on the storage capacity of the memory buffer and also how fast images can be written to your inserted memory card.
So, the higher the resolution the image the more space it takes in the memory buffer. Should you shoot in a smaller resolution you should be able to shoot more frames continuously. However, there are a few variables involved. If the Camera is preset at the factory to not store any more than five images no matter what the resolution than there is no way around this encumbered feature. And, or the speed at which the memory card you use can accept written data will also decide how fast the buffer is cleared for new data.
The highest speed flash memory conforms with Version 6 and has a write speed of 188x.
So, the things to double check is if a limitation is built into your camera of five images and no more than five no matter what the resolution. This is not uncommon. The second is the speed at which data can be cleared from the buffer and written to the memory card, less common but a newer standard now that faster flash memory cards are becoming available.
Now, all that being said, There are 'firmware' updates released from time to time that make adjustments to camera features than can change these variables
Most Nikons use Compact Flash so see if you can get a high speed card that is version 6 compliant. But, first, check the sony support site for your camera and see if 5 is the limit no matter what. And if so, see if there is a firmware update under downloads at the support site that increases the number of shots that can be stored in buffer while being written to the flash memory card.
I have a client wtih a D60 who when she switched over to 133x Compact Flash was able to shoot more frames faster in continuous mode.
Please don't hesitate to use the comment text box below for any further assistance, such as the support page at Sony for your camera if you don't have in in yoru manual. Or any information you may need regarding shooting in high speed mode and what format to use. Most Pros that consult with me are using JPEG uncompressed. If you have questions please provide more detail on how you have your camera setup and under what conditions you are shooting in when attempting to capture more frames per continuous mode shotting.
Regards,
Worldvet
Jan 14, 2009 | Nikon D300 Body Only Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
LG GW300 Cell Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
