Question about Electrolux Heating & Cooling
Carrier model ese30cra changed outdoor unir pc board as it was burnt and shorted out due to lizard. Unit no longer trips c/b but new pc board has led 1 red light on and the indoor unit has continuous green light flashing after about 5 minutes
  • 659 Answers
SOURCE: carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
  • 4090 Answers
SOURCE: LG split (3 indoor) LMU360CE
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Posted on Aug 02, 2009
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Have you found the problem with ya A/C yet PD with the U4 code, if so what was it.
Posted on Jul 27, 2010
vetteman3002
  • 2299 Answers
SOURCE: F26 ALARM ON CONTROLLER. UNIT
Have you tried turning the power off and letting everything reset? If so and you are still getting the code, then I will need to know what model the unit is. Thanks!
Posted on Mar 01, 2011
What to do with carrier infinity ac fault code 81
"Low capacity thermal lockout"#81. What this tells me is your 1st stage cooling(low capacity) is locked out for 4 he's due to a dirty outdoor coil, weak outdoor fan motor run capacitor, slow outdoor fan motor, overcharged with freon, restricted or short cycling outdoor airflow(overheating), damaged discharge temp switch, faulty outdoor circuit board. That's all the scenarios I can think of for now. Hope this helps!
Aug 24, 2017 | Carrier Heating & Cooling
Model 42pfl3609/98. Why doesn't it turn on?
With all of those bad parts on PS sure there are more. Why not replace the board with a new one?
Mar 29, 2013 | Televison & Video
Carrier thermostat blank lcd display
Like have a clogged drain and the float switch is tripped. Check the drain line near the indoor unit for a piece with two wires. Remove switch and check for water or look in emergency pan under unit for water. DO NOT LEAVE SWITCH OUT, must vacuum clog free or blow out with compressed air.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 09, 2017 | Carrier Heating & Cooling
I have a Wall mounted Fujitsu Air Con unit (AOT9LSAC) and will only blow room temp air. The green timer light continualy flashes and the red led opperation indicator flashes 8 times. Can you advise me as...
I have exactly the same problem. Pulled apart the outside unit (condenser) and found lizards have crawled under the circuit boards and been cooked. The circuit boards look all burnt and I suspect this is where the damage is. I have removed the boards but not sure where to get replacements.
Nov 13, 2011 | Fujitsu Heating & Cooling
I have a split a/c hitachi model number RAS-3HQE5 it stopped working the other evening, i have power to the outdoor unit when i removed the cover i found a mouse shorting across the power supply...
The shorrting could have damaged the control board and so the board commands must be checked. The output to the outdoor unit comes from the processor in the indoor unit and so checking the working of the processor is important. It is possible that the short could have damaged the circuit and so a trace is need on the tracks that was shorting.
Tip: Check the LT circuit from the mains as the high voltage could have flown into to damage the circuit.
Aug 31, 2011 | Heating & Cooling
I have a Jandy Aqualink RS system. The wires for one of the valve activators was shorted and the outdoor control panel and the indoor control panel lost power. None of the circuit breakers was tripped.
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Apr 04, 2011 | Jandy AQUALINK RS TELELINK KIT
Carrier hi wall split unit on light flashes 4 times ???
as i am a mechanic in sydney australia, i can honestly say that the chance of you getting help via carrier is very very slim... the reason it is doing that is that it has a legitimate problem unfortunately i have a carrier 42g250h which is flashing 4 times aswell... i have been waiting now 10 working days for carrier to call me to tell me what the problem is... if you can afford to do it, throw the damn thing out and buy a new one, i hate to say it but even an LG will work better than these heaps of ****
Feb 23, 2009 | Carrier 38CKC042 Air Conditioner
Kelvinator Highwall Split Model KSE70CRA
The unit is tripping when the outdoor unit tries to come on. This could be two things, first change the capacitor on the outdoor unit by removing the top cover of the outdoor unit. If this does not solve the problem, your compressor could be faulty
Jan 30, 2009 | Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
