Question about Car Audio & Video
I need a wiring diagram for a Clarion PE-2527-KA Cd player fitted to my 2002 Mits Magna
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
SOURCE: RADIO/CD PLAYER 2002 MITS ECLIPSE GT
You will have to call Mitsubishi for the code if it's not in the Owner's Manual (like my wife's wasn't). Call Mistu with the VIN# and Serial# of the radio at hand.
To get the VIN number, check the bottom of the front window.
For the Serial # from the radio: Remove the two screws under the center console. There is one on each side of the console (you may have to lay on the floorboard to see them clearly). Then pull out the two air vents from the center console (this will help you get a good grip for the next part). Hold the edge of the top of the console and the air vent for either side and pull it towards the rear of the car. I had to wiggle the console pretty vigoursly to get both sides out. Be sure not to pull it too far from the dash right away because you'll need to disconnect the hazard light switch prior to completey removing the console cover. Once that is disconnected you can safely move the console cover. This will expose the mounting braket. There two screws on the side of the mounting braket for the radio. Just unscrew those and you can remove the radio and see the serial number on top of the radio (you may also be able to see it if you just look in the space above the radio while it's still in the mounting braket but I wanted to make sure I had all the numbers/letters correct and didn't have to go through this again). Just do everything in reverse (don't forget to plug the hazard light switch back in!) to get it all back together.
Posted on Dec 02, 2008
SOURCE: my ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Posted on Feb 03, 2009
firemanb0b
  • 5 Answers
SOURCE: used Clarion AB213R radio/cassette: nowiring diagram
go to ur car audio supplier as they should sell wire harnesses premade so its just a matter of plug in & go! The wires all match.
Posted on May 03, 2009
  • 909 Answers
SOURCE: car cd player installation
Yes it will, there is a short wiring loom between the headunit and the cars loom. they are universal and just plug in and away you go.
Posted on May 04, 2009
Need code for clarion PE-2538-KA please
Be prepared to prove ownership of the device, then contact a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
You may have luck with a youtube search.
I trust this information proves beneficial.
Sep 01, 2015 | Clarion Car Audio & Video
HI CLARION CAR CD PLAYER
dear,
can u explain the matter so that i can help u
regards,
dont rate it, until u got it
Oct 03, 2008 | Clarion ARX6670Z Cassette Player
How do I adjust time on 2001 magna radio
Unknown.
Recommend contacting a local car audio professional or Clarion customer support directly here:
Oct 05, 2014 | Clarion CX201 Radio / CD / MP3 player /...
Need to know the color codes to hook up the wires to my DB 335 Clarion CD player, or need the schematics.
While this diagram may not be specific to your CD player, it appears to cover multiple models of Clarion mobile products:
http://www.clarion.com/us/en/support/faq/SourceUnits/Diagram.html
Hope this helps!
Feb 24, 2010 | Clarion DB-335 CD Player
I need to know the wiring diagram for a Clarion
RED 12 VOLTS SWITCHED
YELLOW UNSWITCHED 12 VOLTS
BLACK GROUND
BLUE REMOTE OUT
WHITE,GRAY,GREEN AND VIOLET PAIRS : SPEAKERS
Sep 20, 2009 | Clarion XMD2 CD Player
Clarion db165, need a wiring diagram
i have a clarin db165, and i need a wiring diagram or color sheet.... please! i've looked a;; over the internet with no luck.
Mar 26, 2009 | Clarion (DB165) CD Player
Wiing diagram clarion PE-2528-KA needed
Can you please send me the wriring diagram for a clarion pe-2528-ka radio/cdplayer.As it has been taken out of the car and the wires were cut. I need the wriing to put it into another car. Thanks Glenn
Feb 28, 2009 | Car Audio & Video
Clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Aug 03, 2008 | Clarion ARX6670Z Cassette Player
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
Car Audio & Video Logo
349 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
