There's a "language" menu that is on the screen every time I turn the tv on. I've bought 2 universal remotes to try and select the "ok" or "enter" option, but nothing seems to be working. Also none of the buttons that are on the physical tv are working either, except the power button
  • 11,800 Answers
The control processor on your tv has been locked and the entire control board must be either reflashed (some newer tv's allow that so you can fix it) or replaced. Since you didn't provide the exact model of the tv i can't point you to a site from where you could buy a replacement board.
But putting a new board is still quite a complicated job. If you aren't sure you can do it without damaging the rest of the tv then you must take your tv to a repair shop, it will be a lot cheaper than calling one home.
Posted on Aug 07, 2010
  • emailmikedea Aug 07, 2010
    Ok. Thanks. It's model no.MD14H63. Is there something I can do, or do I need the repair shop?
  • Azrael SRL Aug 07, 2010
    I did a search thru all my bookmarked parts sites and i couldn't find a replacement board for your tv. Because of that i think you should take it to a repair shop, they can order a new one thru their business connections. But beware - the entire job will cost you around $125, it might just be cheaper to get a new tv from a sale.
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
How d I activate an external antenae
1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
Aug 15, 2013 | Toshiba Ct885 Remote Control
Language menu
Hi Fernando..Yes your TV can support Spanish language.It is easy to change your menu language to Spanish.Please follow these steps to change into Spanish.
1)Press the menu button using your remote.
2)Wait for the menu to be displayed.Once the menu is displayed click the language menu from the display.
3)You can find all the languages listed on the menu.
4)Select and Press OK to activate your language.
5)Press Enter and Exit.
Enjoy watching your TV with Spanish menu..
Mar 23, 2013 | Samsung UN46D6050 TV
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
How to get subtitles in english .they are coming in another language
Hello
To select the language, do the following.
[1] Press Menu and the press Left or Right arrow on the remote to select language option.
Choice of language selection [3] will appear on the screen.
English, Espanol and Francias
[2] Press Up or Down arrow to select the desired lannguage you want to be displayed on the screen. Then press ENTER.
[3] Press Menu repeatedly to exit the Menu screen to be cleared.
OK.
Jan 11, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
Menu on remote will not work
If you are saying the white square is coming up when you are viewing TV it sounds like the closed caption is on, try o turn that off first. If that is not what you are describing then I am lost as to how an original remote does not have the funtions on it that are required to navigate the system
Feb 27, 2009 | Televison & Video
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
No code
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
