Question about Fisher and Paykel GWL11 Top Load Washer
Top loader.recently had sesor replaced after machine went off balance. has gone off balance again, now water pumps for a second then stops and sarts then light sequence comes on.
    Problem Solver:
  • 14 Answers
David, exactly what combination of lights come on, top row. There are 8 leds 5 green, 2 orange, 1 red. Show the code with an X for led on & 0 for light off. EG:
0000X00X
This will indicate F9, sizing issue. (Code is actually read Right - L)
Also is model # GW711 What is product code. Both available on back panel or behind control panel.
Posted on Aug 07, 2010
I have a gwl11 top loader that keeps stopping through the cycle what could this problem be
Problem could be out of balance switch, RPS sensor, failed water valve, faulty pump, please be more specific :)
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Roper top loader direct drive washing machine vibration on spin
the counter weights inside gone bad or u need to balance the machine legs , use a leveler to check balance
Nov 12, 2008 | Roper RAS6233KQ Top Load Washer
1999 Astro van water pump
water pump has bad bearing causing it to stop .replace water pump
Oct 19, 2008 | 1999 Chevrolet Astro
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
109 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
