Hard drive i have a compaq evo N620c but just lately its been running slow, so i checked the space left on the hard drive & there is only 1.5gb free space left on it, will i have to replace hard or can i free up more space it, if so howe. Thanking you Reg
  • Byron Wells May 11, 2010
    What is the capacity of the hard drive? There are different ways to approach this problem.
    Scholar:
  • 144 Answers
When you say it's slow what I often found is that
1.not enough memory on your laptop
** so your CPU have to use your harddisk as memory,instead of working directly your CPU have another work to manage thus cos your system to slow down.
** you can check memory usage by right-click on your taskbar and click on Task Manager.Go up to Performance and check
Physical memory and see your available memory.
2.use more than one anti-virus program.Its just like before your work has been check by one program and now somebody is calling your same work to be recheck.Thus cos your system to become really slow.
3.Something is running all the time.A virus or something is running all the time.Shut it down by right-click on your taskbar and click on Task Manager.Go up to Performance and see CPU
usage that its 100%!!!! If so go up to process tab and right click
on the process you think is creating problem and End Process Tree.
3.The combination of not enough muemory and also not enough
harddrive space.When I say not enough harddriver I mean really low about 100-300 Megs.
so in your case not the problem with Harddrive..cos you have 1.5G
takecare.
Posted on Apr 29, 2008
How do i restore my compaq evo n620c to factory settings
If you have the restore disk just run them it will delete the current and install with a clean factory install
Aug 23, 2011 | HP Compaq Evo n620c Notebook
I replaced my motherboard battery in my compaq evo n620c and it still says the same thing before i changed the battery
what does the message say ????? hard to know how to fix something when you aren't told all the problem
Jul 07, 2011 | HP Compaq Evo Notebook N620c
I want to format my hard drive and re install windows xp so i can start a fresh as my comaq evo n620c laptop has too much stuff on it and is very slow with the hard drive thrashing too much. i was never...
Some system come with the option to restore default settings so you will not need the CD. Usually there is a utility tool provided by the manufacturer that you can use within windows to restore factory settings or by pressing alt+F10/F11/F12 at the startup menu, and this will take you to restoring the factory settings. If you have not got the utility installed or there is no partition with the default settings, the following link click here (HP owns compaq so the link will take you to hp website )will take your where you can download this utility for your system. This SoftPaq contains an InstallShield utility that allows the user to restore the original registry defaults for the Compaq Evo N620c. These system default settings include the the default Power management settings. You might have to free space by deleting stuff and uninstalling unnecessary apps it is not exactly formatting but you have no recovery CD and no Partition that includes the factory defaults then I guess it is not a bad option.
By the way Your laptop will have the Authentication key for the operating system of your PC at the bottom of your laptop this I do not know how useful that is but it was worth mentioning good luck
Jun 07, 2011 | Compaq Evo N620c Notebook
My compaq evo nc620c laptop wont boot up, only goes to the "compaq" log screen from where I can go into F10 rom based setup or F12 network boot only.
Without having seen it, it sounds like a hard drive problem. Could be dead, could be the boot info has been destroyed (virus?).
ROM setup should be able to tell you more about the hard drive, and whether Setup can see it.
Apr 03, 2010 | HP Compaq Evo n620c Notebook
WHERE IS THE MEMORY SLOT FOR A COMPAQ EVO N620C
see the back of laptop there is an icon of RAM open that sckrews and put off the cover,
May 09, 2009 | HP Compaq Evo n620c Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
Cannot locate ram on compaq EVO N620c
The RAM is located under a panel on the LHS of the touchpad.
You need a thin blade/knife to slip under this panel to lift it up and out. It is clipped in with plastic catches on the panel.
Dec 17, 2008 | Compaq Evo N620c Notebook
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
