Question about Fisher and Paykel WL26CW1 Top Load Washer
Is there a cleanable filter somewhere - Fisher and Paykel WL26CW1 Top Load Washer
How do I clean the filter
You not not say what vacuum you have, some cannot be cleaned but must be replaced. If yours is cleanable it will have to be removed from the vacuum and blown out or washed. You must be careful as washing some filters causes fine dust. To clog the pores of the filter restricting the airflow.
Feb 25, 2015 | Filter Vacuums
Change the transmission filter on a 1999 Kia sephia?
The filter is inside the transmission and requires the pan to be removed As it is mainly a mesh filter , the auto parts store may not stock it as it is cleanable. Use an accredited transmission shop to do the job
Jan 24, 2015 | 1999 Kia Sephia
My Hetty Hoover has no suction, but when I take the filter out it has suction Please help!
Throw away your old filter if it is not cleanable. Only clean it if it is a washable filter. If not, buy a new one
Dec 10, 2014 | Hoover Vacuums
Clean filter air
Most projectors use cleanable - not replaceable filters. Just remove it, wash it out, dry it and re-install.
Nov 13, 2013 | 3M MP 8745 Multimedia Projector
Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
Jul 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Wheres the oil filter on a 1983 Honda XR200R? and how do you clean it?
A 1983 XR200R does not have a replaceable oil filter. It has a cleanable screen. It is located on the left side of the crankcase behind a large nut. I think it is a 17mm. Remove cover and clean screen.
Jan 30, 2010 | 2002 Honda XR 200
How do I clean the style 8 hepa filter?
that filter is not cleanable. needs to be replaced
Jan 04, 2010 | Bissell Style 8 Vac Hepa Filter Bagless...
I need the fuel line size on Homelite gas blower. Is the fuel filter a washable/cleanable filter?
i think they are 1/8 in hoses on them and if it is a foam filter they are washable,mild soap and then a light coating of oil
Dec 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Does this machine have a removable or cleanable filter? if so where is it??!
there is a filter but it is underneath the machine on the pipe to the pump, you will need to remove a hose clip.
Sep 06, 2009 | Hotpoint WMA46 Front Load Washer
Would like to know if the cleanable f2 hepa filters will work exactly the same as the regular disposable f2 hepa filters in my dirt devil dynamite plus
They should work the same, the advantage to the cleanable ones are you can reuse them for a while. But even those get to a point where cleaning doesn't help. But they should last a few years. The disposable ones you have to replace often, so you just have to decide which is cheaper and better for you.
Jul 13, 2008 | Dirt Devil Vacuums
Fisher and Paykel WL26CW1 Top Load Washer Logo
21 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
