Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
I have an LG 62DC1DA. The operation indicator is blinking orange. The manual says that means preparing operation in standby mode. It seems stuck in that position? What should I do? Thanks.
  • LG Master
  • 11,800 Answers
Either the power source or the control processor have failed. You must take the cover of the tv and test the output voltages from the power source, starting with the one for the bulb. Next you must check the bulb itself ad its ballast. Finally you must check the processor and the IR sensor (sometimes a bad sensor will mess up a processor). Beware, high voltage inside at the bulb.
If you don't know how to do that and lack the minimum necessary tool - a good multimeter, then it's time to call a pro.
Posted on Aug 07, 2010
My Lg 55LD650 seems to be stuck on standby and when you try to turn it on the red standby light starts to flash. Any solutions cheers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 06, 2017 | LG Televison & Video
Helloi am having problem with dell t5400 presionwhen i start my pc and show my desktop few minutesautomatically turn off and orange light blinking do you tell me what the problem with My t5400 precisi
The only blinking orange light is located on the Network RJ45 connection
If you're talking about the Power light on the Front panel:
If the Power light is blinking green the computer is in a sleep state: The computer is in standby mode. Press a key on the keyboard, move the mouse, or press the power button to resume normal operation.
If the Power light is blinking amber indicates that an internal power problem might exist; The computer is receiving electrical
power, but an internal power problem may exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that all components and cables are properly installed and securely connected to the system board.
You can find the User Manual here Product Support Dell US
May 06, 2014 | Dell Computers & Internet
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Two quick flashes problem powerline what does that mean exatly
From the manual.
Some chargers have a Problem Power Line indicator. When the charger is used with some
portable power sources such as generators or sources that convert DC to AC, the charger may
temporarily suspend operation, flashing the red light with two fast blinks followed by a
pause. This indicates the power source is out of limits.
Oct 13, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
Oct 13, 2011 | LG 50PX1D 50 in. Plasma Television
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
