MCL 437F... TOSHIBA CRT TV WITH ONLY HALF OF PICTURE..WITH A vertical blue line in the middle. (only from middle to top got picture)
techman
  • 3130 Answers
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
  • 1153 Answers
SOURCE: Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Posted on Dec 06, 2007
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
  • 4234 Answers
SOURCE: RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Posted on Jan 30, 2009
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
The picture with my television has gone out. The sound is fine but there's only a white line across the middle of the television. How can I fix the picture?
The Toshiba sets are well known for this problem, the tv has a vertical deflection issue caused by the vertical ic and a few small capacitors going bad, I recommend a tv technician for the repairs.
Jan 15, 2011 | Toshiba 36A40 36" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
It sounds like a loose solder contact in the vertical circuit.
maybe on the vertical ic or some caps in the area.
Feb 24, 2009 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Televison & Video Logo
312 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
